How to read a char from FullDuplexSerial without removing it from buffer? — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2012-01-13 09:09 in Propeller 1
Hi,
Actually I am using FullDuplexSerial_rr004 which is quite similar.
Does anyone know how to read a char received without removing it from the receive buffer?
Thanks.
  • Mike GMike G Posts: 2,702
    edited 2012-01-12 19:50
    Sure add a getter to the FullDuplexSerial object.
    PUB GetBuffer(index)
      return rx_buffer[index]
    I have to ask... why??? There is probably a better way to handle your business logic.
    edited 2012-01-12 23:03
    Just add this spin routine to the FDX spin code and call it.
    PUB rxtwice : rxbyte
    '' Check if byte received (never waits)
    '' returns -1 if no byte received, $00..$FF if byte
    '' does not clear from buffer
      rxbyte--
      if rx_tail <> rx_head
        rxbyte := rx_buffer[rx_tail]
    You will notice it is just the routine Rxbyte with the buffer decrement line removed.
    If you just want to know if there is a char in the buffer you can use Rxavail.
    edited 2012-01-13 00:17
    Contextual lookahead. 'Seems legit to me. It can be simpler than unbuffering, then having to stash it temporarily because you weren't quite ready for it.
  • william chanwilliam chan Posts: 1,326
    edited 2012-01-13 01:02
    So for FullDuplexSerial_rr004,
    I just change this line
    rx_tail := (rx_tail + 1) & bufmsk
    to become
    rx_tail := rx_tail & bufmsk
    for the lookahead method?
    Thanks.
    edited 2012-01-13 01:08
    Now I think I get it,
    I should remove this line
    totally for the lookahead method right?
    I feel so stupid, thanks Cluso and Mike.
    William,
    I'm not sure if it would be useful in your case or not, but I modifed Tim Moore's four port serial driver to watch for an end of message character.
    With a 512 byte rx buffer, I just let the message sit in the rx buffer until it's complete and then process the message. It has really simplified a lot of my projects. I don't have to continually move bytes from one buffer to another as I watch for the final byte of the message.
    The modified driver is attached to post #9 of this thread.
