How to read a char from FullDuplexSerial without removing it from buffer?
william chan
Actually I am using FullDuplexSerial_rr004 which is quite similar.
Does anyone know how to read a char received without removing it from the receive buffer?
Thanks.
Thanks.
I have to ask... why??? There is probably a better way to handle your business logic.
PUB rxtwice : rxbyte '' Check if byte received (never waits) '' returns -1 if no byte received, $00..$FF if byte '' does not clear from buffer rxbyte-- if rx_tail <> rx_head rxbyte := rx_buffer[rx_tail]You will notice it is just the routine Rxbyte with the buffer decrement line removed.
If you just want to know if there is a char in the buffer you can use Rxavail.
I just change this line
rx_tail := (rx_tail + 1) & bufmsk
to become
rx_tail := rx_tail & bufmsk
for the lookahead method?
Thanks.
I should remove this line
totally for the lookahead method right?
I feel so stupid, thanks Cluso and Mike.
I'm not sure if it would be useful in your case or not, but I modifed Tim Moore's four port serial driver to watch for an end of message character.
With a 512 byte rx buffer, I just let the message sit in the rx buffer until it's complete and then process the message. It has really simplified a lot of my projects. I don't have to continually move bytes from one buffer to another as I watch for the final byte of the message.
The modified driver is attached to post #9 of this thread.
