How do I turn on an AOpen power supply — Parallax Forums
MoskogMoskog Posts: 556
edited 2012-01-12 06:44 in General Discussion
Does anyone here know how to turn on an AOpen FSB235-60GT power supply?
The power supply is removed from one of my old computers and can be turned on only when attached to the main board and then pushed a button at the computers front panel.
One of the output cables is white and called P.G.signal, I suspect that cable has a key function here.
My plan is to use the 5 and 12V to run a Dell LCD-screen with broken power supply board.
