Source for 2mm connector ?
I have a GPS board whose on-board connector is a male 2x10 header at 2mm spacing. I have been trying to find a reasonable (and secure, due to vibrations) way to plug into it but for the life of me I cannot find an easy to use female 2mm pitch connector. I have found housings which one can use to crimp your own but the crimping tool is $500.
I have found various bits and pieces but some things aren't in stock, others have high minimum orders etc. For example, digikey has ready-made female-female cable assemblies that would work (i.e., part # SAM8536-ND, or SAM8537-ND) but none of the whole series are in stock. They also have 2mm cable ribbon sockets but no 2mm cable, and so on.
I can crimp individual wires with heat shrink around them and plug them one at a time but I was hoping to find an IDC connector/cable combination that I can plug straight in; I can then crimp the other side for mounting on .1" headers, but I will need to find these darn 2mm 20position female connectors!
Any suggestions would be greatly appreciated --
3M 152210-0100-GB at www.Mouser.com
It's an IDC type connector. The specific crimping tool is usually around $15-20, but I've used channel-lock pliers in the past with no problem, a vise would also probably work.
Here is the search I used, there are other choices:
http://www.mouser.com/Interconnects/Rectangular-Connectors/Headers-Wire-Housings/_/N-7aunt?P=1z0wxnwZ1yzv7x1Z1z0wxorZ1yzufxfZ1z0wxou
-- regards
