Source for 2mm connector ? — Parallax Forums
ypapelisypapelis Posts: 99
edited 2012-01-18 21:50 in Robotics
I have a GPS board whose on-board connector is a male 2x10 header at 2mm spacing. I have been trying to find a reasonable (and secure, due to vibrations) way to plug into it but for the life of me I cannot find an easy to use female 2mm pitch connector. I have found housings which one can use to crimp your own but the crimping tool is $500.
I have found various bits and pieces but some things aren't in stock, others have high minimum orders etc. For example, digikey has ready-made female-female cable assemblies that would work (i.e., part # SAM8536-ND, or SAM8537-ND) but none of the whole series are in stock. They also have 2mm cable ribbon sockets but no 2mm cable, and so on.
I can crimp individual wires with heat shrink around them and plug them one at a time but I was hoping to find an IDC connector/cable combination that I can plug straight in; I can then crimp the other side for mounting on .1" headers, but I will need to find these darn 2mm 20position female connectors!
Any suggestions would be greatly appreciated --
