Fuse question/suggestion — Parallax Forums
max72max72 Posts: 1,155
edited 2012-01-11 09:43 in General Discussion
I'm doing a small box with GSM and the propeller, to be used on the go.
It would use 12V from car battery, and have a 6V sealed lead battery.
The 6V will be charged via a L200 chip.
After the diodes (schottky) there will be a 4V switching regulator to drive the GSM, and a propeller board.
Considering the batteries I would like to avoid troubles with shorts, so I'm planning to place 2 fuses.
The attached image shows a block diagram of what I have in mind, and in red the fuses.
Any suggestion is welcome.
Thanks in advance,
Massimo
    edited 2012-01-10 17:04
    That should work. Fuses are important with lead acid and nicad batteries. Fuses would be a few amps?
    edited 2012-01-10 17:11
    Unless the charger has its own fuse you may want to put a fuse between it and the 12V battery as well.
  • max72max72 Posts: 1,155
    edited 2012-01-11 00:23
    The fuses would be a few amps, the idea is to be short safe. I have a cigar lighter adapter with a 5A fuse inside the tip, and I had the (unplanned) opportunity to verify the value is ok.
    kwinn, thanks, I'll move the upper fuse left, before the L200 charger.
    Massimo
  • bill190bill190 Posts: 769
    edited 2012-01-11 09:10
    In general fuses are used to protect the wiring from heating up and causing a fire due to overload or short.
    And the amperage load on wiring should not exceed 80% of the wire's amperage capacity.
    Then there is "voltage drop" with distance. And more so with DC. So if running wires many feet, a larger wire gauge would be needed. Although the fuse could be smaller to protect the device(s) at the end of that wiring.
    Anyway here is a handy dandy wire gauge chart for 12 volts, amperage, and distance of wire run...
    http://www.offroaders.com/tech/12-volt-wire-gauge-amps.htm
    Thanks.
    The current draw is in the 100mA range, with short peaks during GSM communication.
    The idea is to avoid fire in case of a short.
    Massimo
