Fuse question/suggestion
I'm doing a small box with GSM and the propeller, to be used on the go.
It would use 12V from car battery, and have a 6V sealed lead battery.
The 6V will be charged via a L200 chip.
After the diodes (schottky) there will be a 4V switching regulator to drive the GSM, and a propeller board.
Considering the batteries I would like to avoid troubles with shorts, so I'm planning to place 2 fuses.
The attached image shows a block diagram of what I have in mind, and in red the fuses.
Any suggestion is welcome.
Thanks in advance,
Massimo
Thanks in advance,
Massimo
kwinn, thanks, I'll move the upper fuse left, before the L200 charger.
Massimo
And the amperage load on wiring should not exceed 80% of the wire's amperage capacity.
Then there is "voltage drop" with distance. And more so with DC. So if running wires many feet, a larger wire gauge would be needed. Although the fuse could be smaller to protect the device(s) at the end of that wiring.
Anyway here is a handy dandy wire gauge chart for 12 volts, amperage, and distance of wire run...
http://www.offroaders.com/tech/12-volt-wire-gauge-amps.htm
The current draw is in the 100mA range, with short peaks during GSM communication.
The idea is to avoid fire in case of a short.
Massimo
