MOSFETs and the Propeller
idbruce
Hello Everyone
I am starting this thread to gather information pertaining to the control of MOSFETs by the Propeller chip. Feel free to add any information that you may feel is helpful, however I am specifically looking for detailed information, such as schematics, part numbers, resistors and transitors used, etc... Additonally items such as:
I am hoping this will become a nice thread pertaining to MOSFETs that will become an asset to newcomers and old timers alike. Considering my lack of expertise is this area, I personally have nothing to post, but I look forward to lots of input.
I thank you all in advance for sharing your knowledge and any input that you may provide.
Bruce
- MOSFETs that can be directly triggered by the Propeller chip
- Circuts that handle large loads
- Circuits to push small loads
- Anything useful pertaining to MOSFETs and the Propeller
- And absolutely any information about powering inductive loads from MOSFETs
Bruce
In my mind this is very simple. I've connected several MOSFETs to my Propeller directly:
1) Choose a MOSFET which is rated for the current needed. It has three pins; Source, Gate, and Drain. Think of it as a switch between the Source and Drain pins. The Gate is a high impedance input which acts the switch to close when voltage is applied. It draws virtually no current.
2) Connect the Drain to Gnd
3) Connect a resistor between Gate and Gnd - value not important - from 10k to hundreds k will do. This is to prevent the Gate to float and act as an antenna.
4) Connect the Propeller pin to the Gate - if you want to be short-circuit-careful use a 1k'ish resitor in series
5) If the load to be driven is inductive (eg. a relay, motor, etc) connect a fast high voltage diode (>100V) across the load in reverse of the voltage that drives the load
6) Connect the load between +V and the Source pin of the MOSFET
here you go
http://www.nxp.com/products/mosfets/automotive_mosfets/BUK9Y19-75B.html
Looking at the characteristics, it should work OK with the Propeller for controlling large loads.
And the Drain to the load.
Duane
For those of us who know nothing about this, can you explain why?
this should be a good entry point
http://en.wikipedia.org/wiki/MOSFET
from here are many references and links for further info ...
@ there is also an explanation about the difference between nmos / pmos
best regards
Reinhard
Ben
I think JFETs can be used backwards though.
http://search.digikey.com/us/en/products/IRF3708PBF/IRF3708PBF-ND/811850
For lots of applications, you can drive it directly with a Prop.
The only thing I don't like about it is that its metal tab is electrically hot, but I'm told that's normal.
I think it's a lot easier to use a P Channel on the high side. You can then just drive it with an NPN transistor from a Prop pin.
Note what Mike G said about the 'body diode', remember that voltage spikes caused by inductive loads can cause the mosfet to go into 'avalanche' conduction so you may need protection.
Select a low RDSon type as the power wasted by a mosfet (in the on state) = RDSon x ID x ID. Many Mosfets quote their RDSon with the Gate at 10 V ('standard level') or 5 V ('logic level') but for driving from the Propeller look what the RDSon is with the Gate at about 3.0 V.
For high-speed circuits capacitance is important.
See what your favorite distributor has to offer, you should find plenty to choose from. Package is very important, especially if you are switching high currents, the NXP type Leon mentioned is an advanced 'Power SO8' package called LF-PAK.
BTW, generally the "Body Diode" in the MOSFET can't be used as a snubber diode on an inductive loaded circuit.
The snubber diode is a separate diode connected across the load. See the circuit.
I very much like using:
RFP30N06 and IRF3708 power MOSFETs.
And the 2N7000 low power MOSFET for level shifting ans signalling applications.
There is another, the STD50NH02L which is in a small TO-251 package. However, I have not fully tested these yet so will comment on them later.
(Ok, I tested it and have an Ron vs. Vgs graph.)
One must note that any of these MOSFETs will not operate at their full current capabilities because the Prop only delivers 3.3V to the gate. Generally this is less than the optimum drive voltage. However, 3.3V is well above the minimum Vgth gate threshold voltage.
Lastly, I know of no MOSFETs that don't have "Intrinsic Body Diodes" in their structure. I suppose they can be made but they would not be what would be called normal.
Duane
2. The drivers are designed to switch high-capacitance loads very quickly. IOW, they are capable of sourcing and sinking high currents of short duration.
Also, you've got to be very careful about lead routing. You do not want your load return currents passing through the logic portion of your circuitry. That entails joining your load return and logic ground at a single point: the MOSFET source (or current-sensing resistor, if you use one). Just making the connections to a common ground plane is not good enough. Here's an example:
http://www.diodes.com/zetex/_pdfs/3.0/appnotes/apps/an18.pdf
I've used the ZXGD3003 before and it works quite well...
Bruce
That's a very nice circuit. I like it. Thank you.
Bruce
http://www.mouser.com/ProductDetail/Infineon/IPG20N04S4L-08/?qs=HwMeRNENlMbtT64zQ7h8nw%3d%3d
It will turn on at 3v but fully-on it needs 4v (look at: VGS [V] chart, bottom left page 5)
So I recommend to run the signal through HCT buffer/driver with a 5v Vcc for this IC.
http://www.mouser.com/Semiconductors/Logic-ICs/Buffers-Line-Drivers/_/N-50nahZscv7?Keyword=HCT&Ns=Pricing|0
Here is my diptrace lib for it:
http://www.diptrace.com/forum/viewtopic.php?f=19&t=3301
There are a lot of folks within this forum that can truly benefit from your knowledge of MOSFETs and Propeller interfacing.
Bruce
And if you've got a hankering for schematics, then you can use the same search phrase but switch to searching for images, and many admirable things will pop up.
For example, here's Phil's previous schematic with a few things labeled:
I suppose you could filter through lots of that stuff and make a big comprehensive index, especially if you glean information from posts made by gurus like Phil and Jonnymac, et al.
Just a thought. RIght now it seems to me that the forum participation is running a little slow. I guess people are still grieving the global loss of Dear Leader Kim Jong ill.
I don't know if this is a(nother) case of information overload or the 80/20 rule applies. Anyone posting a schematic on the Internets could be an electronics wizard until their contributions are verified. Caveat Googler as the ancients used to say.
This seems like a great start and could be combined with other information for an interfacing cookbook.
If Phil's schematic and Jonnymac's interface for protecting pins will satisfy 80% of the cases if adjusted for N-channel or P-channel and load properties, then this could be all that's needed for most of us. Anything else might be more esoteric or situational based on the load voltages, currents, switching speeds - it may take just a study of the data sheets to match the MOSFET with the load and then hook it up per the schematics. Maybe along with the basic schematics, an understanding of the important data sheet values is all that's needed to make an intelligent selection of parts.
C'est La Vie
Well, if we keep bumping this to the top of the forum, I'm sure it will grow dirty-snow-ball style over the next few weeks. :-)
Actually, I would say you've got this thread off to a very good start. And it's a very good topic, too. I've learned a lot from it and have it bookmarked for future reference. But keep in mind it's a lot to ask for people to do a data dump on everything they know about a topic that has taken them perhaps decades of experience to grok. On this forum it seems that the best way to smoke people out of their spider holes is to post a specific question about a specific problem. That seems to be the best way most forums operate. One tactic that has always worked for me is to say something totally stupid and then watch people come to my rescue.
The problem with P Channel Mosfets is they don't have the ability to conduct the same current for a given size.
Ben
I also noticed yesterday a web page saying they did this using a voltage double circuit, which may be an easier way...
+9V  │ Analog voltage FAN 0 - 3.3V │ │ │ │ │┻┐ 1KΩ  │┐ [URL="http://www.datasheetcatalog.org/datasheet/irf/irlz44.pdf"][color=blue]IRLZ44[/color][/URL] PWM ─┳──────┳─────────────┘╋┘ 0.1µf 0.1µf │   Using that circuit (values based on what happened to be in arm's reach) I was able to vary a 120mm computer fan between 566RPM at 56% PWM (1.85V at output of the filter) to 1449RPM at 60% PWM (1.98V). The fan stopped below 56% modulation and tapered off above 60%, but within that range it was very linear and stable. There's some ripple on the analog voltage, but not enough for a fan to care about.Were you using true PWM or DUTY-mode output? Typically, you do not want or need to run a MOSFET in its linear region to control a motor, as it will dissipate too much heat. (A small fan, maybe, not so much.) The key is to use a true PWM output and just drive the gate without a low-pass filter. That way the MOSFET will either be all the way on or all the way off. (With a DUTY mode input, you will not realize this advantage, since it switches too rapidly.)
In any event, with an inductive load, such as a motor, always be sure to add a protection diode across the load. This will prevent the voltage on the MOSFETs drain from exceeding its spec'd maximum when the MOSFET is switched off.
I think this has been mentioned, but I will mention it again, since it can be a show stopper. ... Assuming you get the correct drive voltage, you must also consider having the correct drive current, or else at high frequency PWM you will never leave the linear operating range of the MOSFET. ALL of the time that you spend in the linear region, you are wasting power in the form of heat that the transistor will dissipate. If the gate capacitance is high, and you have a weak drive strength to the gate you will waste more energy than if the drive strength is rated properly. The transistor will still switch, but it will take longer. On a related note, if the drive signal is too fast (i.e. a high base frequency PWM) the transistor may never leave the linear region.
I should also point out, that the capacitive effects of the MOSFET gate also apply to turning the transistor OFF... if the drive strength to turn the transistor OFF is not adequate, then you have the same scenario.
Matching MOSFET Drivers to MOSFETs
Driving Power MOSFETs in High-Current, Switch Mode Regulators
