XBEE on RCFAST
Hi All,
I am trying to use RCFAST (internal clock) with XBEE Series 1. The code works perfectly on the Protoboard (XTAL) with XBee board soldered to it. The propeller on breadboard (no XTAL) seem to have hard time understanding the XBEE message. The message is coming to Prop (it blinks on an LED). But it seems DOUT (XBEE) byte is not interpreted properly. Do you have any idea or expereince with this setup.
VG.
VG.
I suspect that the Propeller won't startup in RCSLOW because it's already in RCFAST on boot, and it won't fall back when the CLK register is loaded from a SPIN program. I did try explicitly giving the binary value to _clkmode and that didn't work. In the end I used CLKSET to get the Prop into RCSLOW.
Here's a test program to find your clock frequencies:
CON _clkmode = RCSLOW ' _clkmode = RCFAST PUB Main CLKSET(%0_0_0_00_001,20_000) DIRA[0]~~ CTRA:=%00100 << 26 + 0 FRQA:=$8000_0000 repeat
@VG: Can you post your code which sets up the connection? Have you tried a slower baud rate?
I am able to see messages (after using an external 20Mhz oscillator) from XBEE to Prop. If the message is more than 16bytes I don't have any LED Blinks from getMsg module. This happens only with the standalone prop with eeprom and 20MHz crystal not with a protoboard.
Is there a restriction from FullDuplexSerial??? I see the tx and rx bufffers are set to 16bytes. I changed those buffers to larger size. That did not work. Worse even those messages that are less than 16 bytes ended up "0" byte filled. Do you have any clues/suggestions about how to handle this? My messages are upto 30 bytes.
All my communication is at 9600 (very slow, but that's OK).
I have a proto board connected to the prop chip on BB on pins p30 and 31.
con _clkmode = xtal2 _xinfreq = 20_000_000 ' Set pins and Baud rate for XBee comms XB_Rx = 22 '1 for proto or 22 ' XBee DOUT XB_Tx = 23 '5 for proto or 23 ' XBee DIN XB_Baud = 9600 LED_PIN = 20 '16 for proto or '20 ' Set pins and baud rate for PC comms PC_Rx = 31 PC_Tx = 30 PC_Baud = 9600 var byte Message[250] byte MsgSz OBJ dbgMsg : "FullDuplexSerial" XB : "FullDuplexSerial" Str : "Strings3" 'From Strings2 PUB start|val, Val2, i,j, valp1,valp2 'start term dira[LED_PIN] :=1 LEDon(1) '1 dbgMsg.start(PC_Rx, PC_Tx, 0, PC_Baud) ' Initialize comms for PC LEDon(0) LEDON(1) '2 XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize comms for XBee LEDon(0) LEDON(1) '3 LEDon(0) DbgMsg.tx(13) DbgMsg.str(string("Hello!! I'M Alive!!",13)) i := 0 val := 0 repeat val := XB.rxcheck if val <> -1 'LEDon(1) getMsg(val) LEDon(0) Delay(10) pub getMsg(ValA)|Valp1,Valp2,Val2,val,i 'Check if the first character matches with the first letter of head i:=0 if ValA == "A" Message[i++] := ValA else return DbgMsg.str(string("Rx:")) repeat 45 'Wait no more than a total of 45 seconds. Need to break this if there is infinit loop and waiting for message val := XB.rxcheck 'Original: XB.rx Val2 := val if (Val2 > -1) Message[i++] := Val2 if Valp2 == 88 and Valp1 == 89 and Val2 == 90 'sequence XYZ received Message[i] := 0 'Zero terminate the string to be safe. But zero could be in payload. Maintain size repeat j from 0 to i LEDon(1) LEDon(0) XB.Tx(Message[j]) return Valp2 := Valp1 Valp1 := Val2 pub LEDon(Val) outa[LED_PIN] := Val delay(500) {{ Clock Functions }} Pub Delay(mS) '' Delay ring '' Delay(1000) ' pause 1 second waitcnt(clkfreq/1000 * mS + cnt)
After a lot of trials I noticed 16characters is limit on regular FullDuplexSerial. Cruso99 made a simple fix in FullDuplexSerial_rr004 to be adjustable upto 256 (in 2 powered numbers.) Thanks to all those who helped me or directed into the right thing.
VG
