Proper insertion of sintered bronze bearings
Hello Everyone
For several years now I have been messing around with sintered bronze bearings, but I never learned the proper procedure for installing them. During my afternoon research, I came across an article which describes the proper procedure and I thought I would share the information. Most of you probably don't need the information, but for those folks that use sintered bronze bearings, it is nice information to have.
http://copper-casting-alloys.brass-copper-fittings.com/oil_impregnated_bronze_bearings.htm
Bruce
Bruce
"Wait a minute! You taught Phil something!"
Bruce
Bruce,
I guess what I meant to say is that was a great link! Thanks for sharing!
Jim
TCIII
http://www.symmco.com/pdf/pilot-drvr.pdf
Oh, and put the bearings into a freezer for 10 minutes or so before you quickly press them into place...
-Tommy
Why put them into the freezer for ten minutes before pressing them in?
Bruce
I vaguely remember reaming that type of bearing to size after pressing it into position, when I replaced one on a motorbike I had nearly 50 years ago.
Just a thought.
TCIII
Everything should be ready, the press should be at the right height, the die should be in place,
In fact, its a good idea to practice the whole operation while you wait for the bearings to chill.
When you are ready to go, just stab the pilot into the bearing, place pilot tip into the race, and start pumping...
-Tommy
Bruce
Same principle as replacing wrist pins in pistons.
Heat piston, freeze wrist pin. It put a lot less pressure on the components like a hydraulic press would.
Yea, I don't know what I was thinking. After the first response, I said "A DUH"
Dip it in oil too, and hope that makes up the .003...
If you like calculators, check this out..
-Tommy
This hole should be drilled undersized then reamed to the final size.
The proper size for the bearing is giving by the manufacture in most cases.
I wouldn't use any heat, But freezing the bearing will make it a little easer to install.
You can buy adjustable reamers if your using inexpensive/lower quality bearings that very in O.D.(Like I do for low duty-cycle projects.)
If your installing the bearings in some hard material, I would use a hone to get the finished hole size (major bearing journal Dia.)
(Adjustable reamers tend to chatter on hard stuff,The hone doesn't)
If you get the O.D. rite the press-fit will be rite and the I.D. will be rite.
No drag---
Making the journals parallel and on center is a whole new story.
Success!
Bruce
EDIT: And as an added bonus, I now have a pilot for a bearing size that I use fairly regularly.
To install round sleeve bearings (brass, sintered, plastic, aluminum):
First, use measuring tools!
Check dimensions of the hole and bushing before installing!
Second use "machinary handbook" or ask me if you wish. To find out what dimensions should be.
Depending on ratio: hole ID/bushing OD you will need to use nitrogen, freezer, press or just hummer.
It is always nice to have any sort of "piloting".
I am making/ installing/designing bushings of all kind every day.
Send me your questions.
I will be glad to help you!
Mechanical Engineer
I just thought of something. Installing sintered bronze bearings without an adjustable reamer can be an arduous task, because these bearings require an undersize hole and the drill bits that are readily available will not create the proper size hole. If you are installing sleeve bearings in aluminum, you should be able to modify a drill as I have outlined in this thread, to give you the proper size diameter hole: http://forums.parallax.com/showthread.php?140164-How-To-Make-Shaft-Couplings-Backyard-Style This may also work with steel, although I have not tested it at this point.
Bruce
Reamers are very expensive, especially for the hobbyist just needing several sleeve bearings. For a single reamer, you better be able to invest $30+ as compared to a $3+ for a drill bit.
Bearings' run in the .0001" range.You wont hand grind a drill that will fit this bill.
Think like a Machnist....Not an Electrician....
You must not have investigated the link in the first post
Even an accurately-ground drill bit is no substitute for a reamer. The two operate in entirely different modes. A drill bit cuts only on the end -- not on the sides. Once the initial hole size is established by the end cut -- which, by its nature will be too imprecise for close-tolerance work -- no further cutting takes place. A reamer, by contrast, cuts on it sides, which sides can be precision-ground to the correct diameter. For precision work, a drilled hole can never be more than a pilot for a good reamer. Just spend the money. You won't regret it.
