Davis Anemometer
Sal Ammoniac
Anyone have any experience with the output of the Davis anemometer?
Are the pulses clean or do they have bounce?
I have some experience with a MetOne anenometer from about 15 years ago. This was probably my first major BS2-IC project and I had some really solid assistance from Chip to get it running. We used the PULSIN command after trying a few alternatives with COUNT and it worked nicely. The challenge was converting the data to sensible units in MPH, so we hooked up an LCD and drove down the street at various speeds in his '93 Corvette. I hung out the window while Chip yelled out the speed and I recorded the units for each speed from the Scott Edwards 2x16 Serial LCD. Got back to the office and (doh) discovered a nice linear relationship.
Tracy Allen has all kinds of experience with his environmental dataloggers. I bet he'll show up on this thread and tell you what you need to know about the output and debouncing issues from an anenometer.
I didn't answer your question but shared an experience.
I used in the past a solid state wind sensor from http://www.mierijmeteo.nl
The price tag is very different, but you have not moving parts, and you get serial data in a string format similar to GPS.
Upward in the price ladder you have ultrasonic sensors..
I've used Davis equipment for years, and their factory is just a few miles from my office. You are in the SF Bay area too, aren't you? The anemometer does use a reed switch, and it does bounce but never more than a millisecond. An RCcircuit and/or software debounce can take care of it. It is a nice anemometer with economies of scale and a lot of history behind it. The potentiometer will be the first thing to wear out, non-replaceable unfortunately. It would be a nice hack to make it all solid state.
Almost similar to my own test driving a dark night some years ago.
This home made anemometer is made of dippers and an used rotary encoder from a steel plate cutting machine. (1000 pulses/revolution) Overkill but I need just 20ms to get a nice byte out of it. And I got it for free.
I'll give the Davis unit a try as it is relatively inexpensive and is made by a local (to me) company. I'll go with an RC debounce circuit as I want to count pulses directly with one of the Propeller's counter modules.
Thanks also for the amusing anecdotes regarding calibration. My son's high school has a wind tunnel, so I'll take it there for testing and calibration.
I'm seeing some funny results trying to count switch closures in Spin code. I'd prefer to use one of the cog's counter modules in NEGEDGE detector (%01110) mode, but I'm getting high readings versus using waitpeq to count the switch closures directly in Spin. My code looks like this;
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ LCD : "HD44780" Num : "Simple_Numbers" PUB Main | upcounter LCD.LCDInit(0) LCD.LCDCls dira[25]~ phsa := 0 frqa := 1 ctra := %01110_000 << 23 + 25 waitpeq(|<25, |<25,0) ' wait for P25 to be high upcounter := 0 repeat waitpeq(0, |<25,0) ' wait for P25 to be low waitcnt(clkfreq/1000 + cnt) ' wait 1 ms for switch bounce waitpeq(|<25, |<25,0) ' wait for P25 to be high upcounter++ LCD.LCDGotoXY(1, 1) LCD.LCDPuts(Num.dec(phsa)) LCD.LCDGotoXY(1,2) LCD.LCDPuts(Num.dec(upcounter))The circuit is simple. I'm pulling the switch closure line up to 3.3v through a 10K resistor and connecting it to the Prop via a 220 ohm resistor, I've also tried a simple RC circuit using both a 0.1uF and a 220pF cap.
When I spin the anemometer with a little mechanism that generates a fairly repeatable 18 rotations, I get the following results:
No cap: "counter" counts: 53 "waitpeq" counts: 18
0.1uF cap: "counter:" counts: 627 "waitpeq" counts: 18
220pF cap: "counter" counts: 36 "waitpeq" counts: 18
I've attached scope traces of the switch closure with and without the 0.1uF cap. The trace using the 220pF cap looks very similar to the one without the cap.
I'd much prefer to use the counter module rather than counting closures directly in Spin. Anyone have any ideas how I can clean up the signal so it doesn't glitch the counter?
As an aside, I wonder why Davis didn't spend a few extra pennies and use a Hall effect sensor rather than an antique reed switch...
I don't know why they don't use a Hall effect sensor. It requires power, but they already have a power there for the vane. I probably has something to do with long tradition and the simplicity of it. Why tinker.
I'll probably implement a hardware solution to the bouncy reed switch in the anemometer with a MC14490 or equivalent. This is a one-off hobby project, so the $5 cost of the chip isn't an issue, and I'm sure the Davis tipping bucket rain gauge, which I haven't looked at yet, has the same issue with contact bounce.
You're right about the digital noise. I've got everything on a solderless breadboard right now, and that, along with the 40 feet of cable attached to the anemometer, are probably picking up lots of noise from all the "projects" running on various development boards on my bench. I'll clean this up in the eventual PCB version of the project.
