Looking for someone with Laser cutting capabilities for a prototype project
My project involves using a Hammond case with plastic end caps. I have attached a picture of the end cap with a simple drawing of an approximate shape of what I need cut out. The material is black ABS 2.5mm thick. I will provide a more detailed dimensional drawing to the person that will do the job.
Will the Laser cut this material ok and what type of edge will it leave?
http://mountainkingtech.com/
Bill
...Tiger
I just bought a laser cutter. With your ABS being only 2.5mm, I think I can cut that quite easily. I've already done a bit and it worked ok.
If you want, you can send me a sample of yours and I'll try it and see what it looks like.
Bill
Any suggestions to avoid this?
Try cutting them from the back, for one.
And I got them just to have a little fun making some of my projects around here. I actually bought one while I had an eBay bid on another. It was one of those bids that you thought was way too low to win... but I won it anyway... so now I have two lasers! :-) One is a small 40 watt desktop model and the other is a large 24"x36" 50 watt unit. Both are made by Redsail in China.
Bill
