Pin Problems — Parallax Forums
Pin Problems
nrsmacnrsmac Posts: 42
edited 2011-12-19 13:14 in BASIC Stamp
Ok, so I have my BOE with my basic stamp. Whatever I connect to PIN 1 goes HIGH. When I use it as IN1, It stays as a 1.
I have checked for shorts. Don't see any though. What is wrong with my pin? Is this hardware related? or is it software related? How do I fix this problem? Thanks in Advance
    edited 2011-12-19 09:13
    First of all, are we talking about I/O pin 1 (P1)?
    What program is in the Stamp?
    Assuming that whatever program is in the Stamp doesn't set I/O pin 1 to output a high logic level, then you have a short circuit somewhere that shorts I/O pin 1 to the +5V supply, either directly or via some other pin.
  • stamptrolstamptrol Posts: 1,731
    edited 2011-12-19 09:16
    Is the program (intentionally or unintentionally) making p1 an output and putting it high? What device are you connecting to PIN 1 that makes the pin go HIGH?
    When used as an input, is there anything external that connects to +5 volts? It will make the pin look like a "1".
    If you have accidently shorted the pins to ground for an extended period or put a high voltage on the pin you could have damaged the internal circuitry of the the Stamp.
    With more information, we can make a better attempt at helping.
  • nrsmacnrsmac Posts: 42
    edited 2011-12-19 10:39
    My stamp has this problem with every program I run it in. When I connect an LED, regardless of the program, it goes high.
    edited 2011-12-19 10:49
    It's a simple exercise to check, if it's "P1"
    [code]
    Main:
    LOW 1
    PAUSE 500
    HIGH 1
    PAUSE 500
    GOTO Main
    edited 2011-12-19 11:01
    As PJ suggested, load the program he indicated. If an LED attached to I/O pin 1 blinks at a 1 second rate, the I/O pin is good. If the LED doesn't blink, then the I/O pin is bad. It might be the BOE or it might be the Stamp. In that case, contact your distributor or Parallax if that's where you got it.
    If all else fails, remove the Stamp from the board and see if you still get +5V at the socket for the suspect pin.
