make problem with latest alpha package?
Here's a make that should work if you're having trouble.
Download and extract make.exe to your c:\propgcc\bin folder.
F
Yes, only a windows problem -- we distribute a make.exe in the windows .zip file, and the one I included last time had some dll problems. It should be fixed in the v0_2_1 packages.
Eric
In the windows version, I also noticed a problem with the master/top demo Makefile for Windows. For me, it errored out trying to build the first demo. The error was:
C:\propgcc\demos\make make -C toggle/cog_c_toggle # TODO build fails. fix later. make[1]: Entering directory 'C:/propgcc/demos/toggle/cog_c_toggle' make[1]: *** No rule to make target '#'. Stop. make[1]: Leaving directory 'C:/propgcc/demos/toggle/cog_c_toggle' make: *** [all] Error 2
I think I fixed it by putting the comment "# TODO build fails. fix later." on its own line in ./propgcc/demos/Makefile. Its been a while since my make101 class, but I dont _exactly_ remember if you can have comments on the same line as commands. Seems to work now, though.
Anyway, that particular TODO comment is obsolete (it's done :-)) so I've just removed it.
Eric
This causes osx 10.4 to fail because the declaration for links overshadows the global declaration. This same problem passed by in a previous file, although it got reported as a warning, it didn't prevent the compile.
any suggestions (other than remove the -werror flag)
I generally like to fix the actual problem instead of hacking makefiles after the fact.
I'll try to dig in to this. You may have some luck with adding "disable-werror" to the configure options in jbuild.sh before doing the build. Unfortunately adding "enable-werror" does not reproduce the bug :-(.
Eric
Another thing I've noticed lately though is that most automake things think my system is a 10.3 system instead of it's actual 10.4, which is quite puzzling, though I don't know if it's relevant in this particular instance.
One thing is sure though, by the time I get this compiled properly, my system will be a whole lot more up to date. My python installation needed a facelift too, since 10.4 came with 2.3, and m4 also needed updated. This is fun, but it sure is work.
