Can I solder a QFN-44pin propeller using solder paste?
I am trying to finish my UV exposure unit this week (more info here http://www.tonytronix.com/myprojects/uvexposure.html) I have some experience with soldering QFP chips with paste but have never tried a QFN. Parallax is out of 44 pin QFP chips. So my options are as follows:
- use a QFN and solder paste (reflow oven)
- use a QFN and socket (I don't know a good place to get a socket without having to pay $6.00 shipping for a $1.00 part)
- wait for the QFP to be in stock.
Solder paste is normal for all parts. So I presume you mean using a soldering iron. I have not tried QFNs yet but others have successfuly done this. You do need to be more careful with the amount of paste applied.
No, there is no metal plate under the QFP. You can put traces and vias under there.
Sometimes this makes the design more compact than a QFN based design (where you can't put anything under except a ground pad).
