Bogey/Wheel Encoder — Parallax Forums
Bogey/Wheel Encoder
ercoerco Posts: 20,263
edited 2011-12-09 09:13 in General Discussion
Found this on Ebay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390370365711&ssPageName=ADME:X:RTQ:US:1123
Looks like a ready-to-go bogie assembly with an encoder inside. I emailed the seller for more info and PPR, he's not sure:
"Thank you for your kind message.
Sorry we not sure about how many pulses per revolution.
Yes,the two wheels are locked together.and Just one encoder.
Please feel free to contact us if you need assistance.
- sicilydreamer"
But it's out there if anyone needs such a unit. Die cast wheels, rubber tires. 6 wires coming out, it may be a quadrature encoder.
    Looks like the guts from a surveyor's measuring wheel. Given the diameter of the wheel the resolution may be as little as 1/10th of a foot (a bit more than 1" linear), which isn't bad. If the wheel is as their eBay post says, and it's part of a process control contraption, then the resolution will be down to millimeters, or less.
    Can't use these on a robot unless it only goes straight. The dual wheels would restrict the robot in turns. Maybe you could remove one of the wheel?...
    The extra leads could be for things like an index track, or it may be a 4-bit absolute encoder.
    -- Gordon
