Questions concerning Understanding Signals Activity #1 and #2 results — Parallax Forums
tgiftgif Posts: 2
edited 2011-12-08 16:59 in Accessories
After performing the Ground Test activity, from Understanding Signals, I get the results shown in the attached screen shot.
I do not understand the spikes on the left side of screen.
Shouldn't it be a flat line?
When I perform the Vin and Vdd measurements I get the following results:
Again, shouldn't these be flat lines?
I am using a Board of Education.
Wiring done per manual.
  • DonBDonB Posts: 5
    edited 2011-12-07 13:40
    I got the same results. I think we are picking up some inductive signals in the hardware. I found if I turned the scope off and on again the spikes went away for a time, otherwise I got the same results as the lesson.
  • hover1hover1 Posts: 1,929
    edited 2011-12-07 15:45
    @tgif,
    Since you haven't gotten a reply to the problem, I would suggest you contact Parallax directly at support@parallax.com . They don't always monitor the forum on a daily basis. I'm sure they want to be aware of any problems.
    I am going to run through that activity to see what I get.
    What version PropScope software are you using? Ver 2.02 is the latest.
    http://www.parallax.com/go/propscope
  • tgiftgif Posts: 2
    edited 2011-12-08 04:28
    Thank you for the responses.
    hover1:
    I am using v2.02
    I will contact service.
    DonB:
    I also got the exact same results that you did upon turning it off/on. Spikes returned soon after.
    Just got a chance to pull out my Prop Scope and went through the activities.
    Verdict: I got clean flat lines on both activities with Ver. 2.02 and 2.03 software. No anomalies like those that were shown
    Hope you get a better answer from Tech Support!
