Ping resistor
Hi
Just a question. Im new in electronics, so probably I'm making a calculation error. In the documentation of the ping object it is stated (depends on version) to use a 1K ohm or 3.3K ohm resistor. But when I'm calculating the needed resistor R=V/I I need
- A volt drop of 5-3.3=1.7V
- It uses 0.02Amp
So that would lead me to 1.7/0.02=85Ohm.
What is the reason to use a much higher resistor?
Patrick
- It uses 0.02Amp
Patrick
http://forums.parallax.com/showthread.php?133557-Is-the-Propeller-Chip-compatible-with-the-Max232-level-shift-IC&p=1024497#post1024497
But the tl;dr for that whole thread is this quote from Phil Pilgram:
1.4 / 0.0005 = 2.8K
I tend to use 3.3K as it's the next standard value, but 4.7K is fine, too; as Martin points out you're just limiting current into the pin, you haven't changed the "high" level seen by the Propeller.
It would be nice if there was a Wiki for the Propeller where the forum morsels could be documented. Then I'd have something to link to for my Wikipedia updates!
Damn bastards at Wikipedia don't allow original content, it must all be borrowed from somewhere else!
