Ping resistor — Parallax Forums
Ping resistor
PatrickS1981PatrickS1981 Posts: 17
edited 2011-12-06 14:41 in Propeller 1
Hi
Just a question. Im new in electronics, so probably I'm making a calculation error. In the documentation of the ping object it is stated (depends on version) to use a 1K ohm or 3.3K ohm resistor. But when I'm calculating the needed resistor R=V/I I need
- A volt drop of 5-3.3=1.7V
- It uses 0.02Amp
So that would lead me to 1.7/0.02=85Ohm.
What is the reason to use a much higher resistor?
Patrick
    edited 2011-12-06 05:47
    Resistors limit current that flows through them. The voltage that drops across them really depends what comes next in the circuit. The issue of what resistance value to use for 5 volt to prop inputs has been discussed a fair bit on the forum. Here's one that I started:
    http://forums.parallax.com/showthread.php?133557-Is-the-Propeller-Chip-compatible-with-the-Max232-level-shift-IC&p=1024497#post1024497
    But the tl;dr for that whole thread is this quote from Phil Pilgram:
    Martin,
    If you use the MAX232, use at least 2.2K and, preferably, 3.3K series resistors. The reason is that the Propeller's input protection diodes are only rated to 500uA. (5V - (3.3V + 0.6V)) / 500uA = 2.2K. That's with the full 0.6V forward voltage drop of the diode. At only 500uA, it may not be that high. If the voltage drop were zero, the formula would be (5V - 3.3V) / 500uA = 3.4K.
  • JonnyMacJonnyMac Posts: 9,396
    edited 2011-12-06 06:55
    Assuming just a series resistor into the pin... the voltage across your resistor, no matter what size, will be 5 - 3.6 (3.3 + 0.3 for the protection diode) = 1.4v. If you limit the current through the protection diode to 500ua (section 7.1 of data sheet), you get
    1.4 / 0.0005 = 2.8K
    I tend to use 3.3K as it's the next standard value, but 4.7K is fine, too; as Martin points out you're just limiting current into the pin, you haven't changed the "high" level seen by the Propeller.
  • PatrickS1981PatrickS1981 Posts: 17
    edited 2011-12-06 08:49
    Thanks. I see now where I made my mistake. I took the Amp's from the ping sensor, not the amps from the input pin of the prop.
  • pedwardpedward Posts: 1,642
    edited 2011-12-06 14:08
    This is really useful information, wrapped up in something else. Is there any place that clearly states: "To make the Propeller 5v tolerant on inputs, use a 3.3k resistor, and this is why..."?
    edited 2011-12-06 14:19
    Yes and no. There's this thread, but it was started before the Propeller chip was fully characterized and contains some bad advice (e.g. 1K series resistors).
    Seems like something useful for the kickstart wiki? Or is that too formalized, it would be information overload?
    It would be nice if there was a Wiki for the Propeller where the forum morsels could be documented. Then I'd have something to link to for my Wikipedia updates! :lol:
    Damn bastards at Wikipedia don't allow original content, it must all be borrowed from somewhere else!
