New to programming, Object avoidance bot. How's my programming look??? Thanks!
Alright, it is for a BOE bot for object avoidance.
Using:
BS2
2 motors (not servos),
1 servo w/ PING))) sensor
I won't have an opportunity to actually test the code until tomorrow. I'm sure something will be wrong with it though. I would appreciate it if anyone with expirience could read through it and let me know why I might have any problems. Thanks!!
Again, Thank you! I don't exactly know what I'm doing yet.
Using:
BS2
'Mad Max is about to blow something up - MadMax.bs2 ' {$STAMP BS2} ' {$PBASIC 2.5} 'Definitions----------------------------------------------------------------- DEBUG "I'm bad company." 'I/O Pin Definitions LeftMotor PIN 0 RightMotor PIN 1 Servo PIN 14 Ping PIN 15 Audio PIN 7 Speakers PIN 8 'Constant/Variable Declarations time VAR Word 'Variables - name/VAR/size, word (0-65535) rawDist VAR Word 'bit(0-1), Nib(0-15), Byte, (0-255) counter VAR Word inches VAR Word leftvalue VAR Word rightvalue VAR Word RawToIn CON 889 RawToCM CON 2257 Trigger CON 5 Scale CON $200 IsHigh CON 1 IsLow CON 0 'Motor Initialization PAUSE 2000 LOW LeftMotor 'Initalize motor I/O pins to output low LOW RightMotor HIGH LeftMotor HIGH RightMotor PAUSE 100 'Let the motor circuits wake up FOR counter = 1 TO 10 'Servo center PULSOUT Servo, 720 PAUSE 20 NEXT 'MAIN------------------------------------------------------------------------ DO GOSUB Get_Sonar IF (inches < 8) THEN 'When obstacle is less than 8 inches away: PULSOUT LeftMotor, 2000 'motors stop PULSOUT RightMotor, 2000 PAUSE 500 GOSUB Servo_Look IF (leftvalue < rightvalue) THEN GOSUB Turn_Right ELSEIF (leftvalue > rightvalue) THEN GOSUB Turn_Left ELSEIF (leftvalue + rightvalue < 5) THEN GOSUB Turn_Around ELSE GOSUB Turn_Around ENDIF ELSE PULSOUT LeftMotor, 3000 'Left motor forward full speed PULSOUT RightMotor, 3000 'Right motor forward full speed ENDIF LOOP 'SUBROUTINES------------------------------------------------------------------ '-----------SONAR------------------------------------------------------------- Get_Sonar: 'Gets sonar from straight ahead Ping = IsLow PULSOUT Ping, Trigger PULSIN Ping, IsHigh, rawDist rawDist = rawDist */ Scale rawDist = rawDist / 2 inches = rawDist ** RawToIn RETURN Get_Sonar_Left: 'Gets sonar from left Ping = IsLow PULSOUT Ping, Trigger PULSIN Ping, IsHigh, rawDist rawDist = rawDist */ Scale rawDist = rawDist / 2 leftvalue = rawDist ** RawToIn RETURN Get_Sonar_Right: 'gets sonar from right Ping = IsLow PULSOUT Ping, Trigger PULSIN Ping, IsHigh, rawDist rawDist = rawDist */ Scale rawDist = rawDist / 2 rightvalue = rawDist ** RawToIn RETURN '-------------------------SERVO MOVEMENT---------------------------------------- Servo_Look: FOR counter = 1 TO 50 'Servo left PULSOUT Servo, 1250 PAUSE 500 NEXT GOSUB Get_Sonar_Left 'get left distance FOR counter = 1 TO 50 'Servo right PULSOUT Servo, 300 PAUSE 500 NEXT GOSUB Get_Sonar_Right 'get right distance FOR counter = 1 TO 50 'Servo center PULSOUT Servo, 720 PAUSE 500 NEXT RETURN '-------------------------------------------MOTOR TURNS------------------------ 'Assuming 1000 turns motor full speed backward, 2000 makes motor stop, 3000 full 'speed forward. Adjust accordingly to align motors. Turn_Left: PULSOUT RightMotor, 2500 'Right motor forward PULSOUT LeftMotor, 1500 'left motor reverse PAUSE 2000 RETURN Turn_Right: PULSOUT RightMotor, 1500 'Right motor reverse PULSOUT LeftMotor, 2500 'left motor forward PAUSE 2000 RETURN Turn_Around: PULSOUT RightMotor, 1500 'right motor reverse PULSOUT LeftMotor, 1500 'left motor reverse PAUSE 1000 PULSOUT RightMotor, 1500 'right motor reverse PULSOUT LeftMotor, 2500 'left motor forward PAUSE 2000 RETURN
How do you go about programming the motors if not from the stamp pins?
