New to programming, Object avoidance bot. How's my programming look??? Thanks!
Alright, it is for a BOE bot for object avoidance.
Using:
BS2
2 motors (not servos),
1 servo w/ PING))) sensor
I won't have an opportunity to actually test the code until tomorrow. I'm sure something will be wrong with it though. I would appreciate it if anyone with expirience could read through it and let me know why I might have any problems. Thanks!!
Again, Thank you! I don't exactly know what I'm doing yet.
Using:
BS2
'Mad Max is about to blow something up - MadMax.bs2
' {$STAMP BS2}
' {$PBASIC 2.5}
'Definitions-----------------------------------------------------------------
DEBUG "I'm bad company."
'I/O Pin Definitions
LeftMotor PIN 0
RightMotor PIN 1
Servo PIN 14
Ping PIN 15
Audio PIN 7
Speakers PIN 8
'Constant/Variable Declarations
time VAR Word 'Variables - name/VAR/size, word (0-65535)
rawDist VAR Word 'bit(0-1), Nib(0-15), Byte, (0-255)
counter VAR Word
inches VAR Word
leftvalue VAR Word
rightvalue VAR Word
RawToIn CON 889
RawToCM CON 2257
Trigger CON 5
Scale CON $200
IsHigh CON 1
IsLow CON 0
'Motor Initialization
PAUSE 2000
LOW LeftMotor 'Initalize motor I/O pins to output low
LOW RightMotor
HIGH LeftMotor
HIGH RightMotor
PAUSE 100 'Let the motor circuits wake up
FOR counter = 1 TO 10 'Servo center
PULSOUT Servo, 720
PAUSE 20
NEXT
'MAIN------------------------------------------------------------------------
DO
GOSUB Get_Sonar
IF (inches < 8) THEN 'When obstacle is less than 8 inches away:
PULSOUT LeftMotor, 2000 'motors stop
PULSOUT RightMotor, 2000
PAUSE 500
GOSUB Servo_Look
IF (leftvalue < rightvalue) THEN
GOSUB Turn_Right
ELSEIF (leftvalue > rightvalue) THEN
GOSUB Turn_Left
ELSEIF (leftvalue + rightvalue < 5) THEN
GOSUB Turn_Around
ELSE
GOSUB Turn_Around
ENDIF
ELSE
PULSOUT LeftMotor, 3000 'Left motor forward full speed
PULSOUT RightMotor, 3000 'Right motor forward full speed
ENDIF
LOOP
'SUBROUTINES------------------------------------------------------------------
'-----------SONAR-------------------------------------------------------------
Get_Sonar: 'Gets sonar from straight ahead
Ping = IsLow
PULSOUT Ping, Trigger
PULSIN Ping, IsHigh, rawDist
rawDist = rawDist */ Scale
rawDist = rawDist / 2
inches = rawDist ** RawToIn
RETURN
Get_Sonar_Left: 'Gets sonar from left
Ping = IsLow
leftvalue = rawDist ** RawToIn
RETURN
Get_Sonar_Right: 'gets sonar from right
Ping = IsLow
rightvalue = rawDist ** RawToIn
RETURN
'-------------------------SERVO MOVEMENT----------------------------------------
Servo_Look:
FOR counter = 1 TO 50 'Servo left
PULSOUT Servo, 1250
PAUSE 500
NEXT
GOSUB Get_Sonar_Left 'get left distance
FOR counter = 1 TO 50 'Servo right
PULSOUT Servo, 300
PAUSE 500
NEXT
GOSUB Get_Sonar_Right 'get right distance
FOR counter = 1 TO 50 'Servo center
PULSOUT Servo, 720
PAUSE 500
NEXT
RETURN
'-------------------------------------------MOTOR TURNS------------------------
'Assuming 1000 turns motor full speed backward, 2000 makes motor stop, 3000 full
'speed forward. Adjust accordingly to align motors.
Turn_Left:
PULSOUT RightMotor, 2500 'Right motor forward
PULSOUT LeftMotor, 1500 'left motor reverse
PAUSE 2000
RETURN
Turn_Right:
PULSOUT RightMotor, 1500 'Right motor reverse
PULSOUT LeftMotor, 2500 'left motor forward
PAUSE 2000
RETURN
Turn_Around:
PULSOUT RightMotor, 1500 'right motor reverse
PAUSE 1000
PAUSE 2000
RETURN
How do you go about programming the motors if not from the stamp pins?
