PropForth4.6 is available for download - Page 4 — Parallax Forums
1246
    edited 2011-11-15 09:15
    caskaz wrote: »
    How do I save forth-code(2_wire_LCD_1.5.f) on internal SD-card?
    Install the SD support per the example in the regression test
    \doc\tests\test-2.1.1.txt (this is the SD tutorial)
    Step 5 loads the sd file system
    Step 6 initializes the SD
    At the end there are two partitions on the SD that can be mounted , USR and SSYSTEM
    via the command mountusr and mountsys, respectively.
    The SYSTEM partion is small, and for forth infrastructure, drivers etc.
    The USR partion is for your application, drivers etc. The main portion of the SD is USR, please try working from this partion.
    sdfs.f shows words for reading and writing files:
    fwrite <filemname> writes a file
    fload <filemname> loads a file (into the interpreter)
    fread <filename> reads and displays a file
    If we did this as we intended, you should be able to look at
    and be able to use the SD support.
  • Ron SutcliffeRon Sutcliffe Posts: 420
    edited 2011-11-15 11:15
    Prof
    fwrite<filename> writes a file from where ????
    Do you fwrite foo.bar then paste the text to the terminal ???
    Do you add it to the top of the file then paste it AKA a script.
    Hence the question.
    There a lot of info but not a specific HOW TO
    Ron
    edited 2011-11-15 11:29
    The examples are scattered through the download package :frown:
    This is one of the shortest scripts creating a file. It is cut from an editor and pasted into the terminal window.
    10 fbwrite .autousr.f
    mountsys
    \ this is now hardwired into the onboot
    \ .autoload.f and thus autousr.f will not be run if the ESC
    \ key is held down during a boot
    \ if esc has been hit the rest of the file does not execute
    \ 6 cogio W@ 27 = c" clearkeys" find -1 = and and execute
    fload ipconfig.f
    fload ipserver.f
    : onreset5
        onreset
        100 delms
        0 cogreset
        1 cogreset
        2 cogreset
        3 cogreset
        100 delms
        ip_init ip_server
    5 cogreset
    It uses the fbwrite word which seems to be favored in all the test scripts. It expects a block count to be on the stack.
    \ fbwrite filename ( numblocks_to_allocate -- )
    The first script says allocate 10 blocks to .autousr.f and copy everything following the fbwrite up to the '...' into that file. the the periods in the last line are IMPORTANT!! They are the EOF indicator.
    That's how every file I've seen put onto an SD card gets created in the 4.5/4.6 release.
    edited 2011-11-15 11:57
    @mindrobots
    Thats the answer that Caskaz was looking for probably looking for.
    @Caskaz
    In the sample scipt that Rick posted....
    Replace mountsys with mountusr, to keep your drivers etc in the usr file system not the sys file system.
    Ron
  • caskazcaskaz Posts: 957
    edited 2011-11-15 18:16
    Hi.
    1block of "fbwrite filename ( numblocks_to_allocate -- )" is 512byte?
    I copy/paste below code to TeraTerm.
    fl
    hex
    10 fbwrite test.f
    mountusr
    : TEST 5 . ;
    decimal
    Result is "UNDEFINED WORD ...".
    Where is wrong?
    edited 2011-11-15 19:40
    1 block should be 512 bytes, if I recall it is the default of the SD card.
    Do you mean "..." is being flagged as undefined? I haven't gotten this message. You may be starting with basic kernel, and not loading the development extensions?
    Did you follow the examples in the regression test and set up the drivers?
    edited 2011-11-15 20:14
    mindrobots wrote: »
    The examples are scattered through the download package :frown:.
    Thanks for the feedback, this helps me determine how to structure the docs. Clearly, lots of work remains.
    The "organize for the user" effort has been on hold till the 5.0 release. Things have been in flux, and have now become stable with 5.0.
    This is where the REAL fun starts. :)
    Currently, the download package consists of all the material (that I requested), in the order that Sal implemented it. The result makes perfect sense to someone that already is familiar with the material (i.e, Sal, as developer) but maybe is not so clear to the rest of us (users). My task is to figure out what Sal did, and put it into words so the rest of us can "just use it" without becoming clones of Sal. Propforth should not require users to have Sal's level of expertise, it should be easy enough for a beginner. It is, or would be with proper explanation.
    The idea for the documentation is: "These are the functions. Here's how to use them. Go play"
    I need your input. Can you give a high level outline of how you need to see the information? How should it best be organized?
    I don't imagine this will be quick or short. We can take our time and be driven by user questions, to ensure we don't waste time on topics that aren't of interest.
    edited 2011-11-15 20:39
    prof_b,
    I've put forth on the side burner until 5.0 comes out. At that point, I was intending on trying to write some documentation and tutorials. I'm currently being distracted by trying to do the same thing with propgcc. I think I learn things better if I try to write about them while I'm playing.
    I'll try to start getting back to thinking about forth as winter swoops down upon us.
    edited 2011-11-15 22:10
    Hi prof_braino.
    I use development kernel.
    And character"..." is not WORD. It is EOF.
    WORD"fbwrite" should search for "...".
    But error occure.
    I think my sample is wrong.
    How can I save forth-code(text file) inside sd-card?
    edited 2011-11-16 01:23
    Cas
    Remove fl from your test.f and you will find that it will work. I have noticed that fl will cause this problem with very short files.
    I think it is when the file are shorter than the input buffer length. I have yet to confirm this.
    See the file below . It works for me. Ron
    hex
    10 fbwrite test.f
    mountusr
    : TEST 5 . ;
    decimal
    edited 2011-11-16 05:47
    Hi Ron.
    I did copy/paste below to TeraTerm.
    hex
    10 fbwrite test.f
    mountusr
    : TEST 5 . ;
    decimal
    ls
    337 .partion-sys/
    130 .sdcardinfo
    136 .autousr.f
    133 .autoload.f
    566 test.f
    Prop0 Cog6 ok
    fload test.f
    UNDEFINED WORD ,
    Prop0 Cog6 ok
    It seem to save test.f in mountsys.
    And test.f cannot load.
    My SD-function is strange?
    edited 2011-11-16 06:26
    Hi
    I tried to assemble on PF4.6 with SD-function.
    I use protoboard.
    assembler-file is below;
    (this is shift-in/shift-out for sd_driver.f.)
    fl
    hex
    :asm
    \ bitmasks for the various control pin
    v_sd_do
    0
    v_sd_di
    0
    v_sd_clk
    0
    a_sd_shift_out
    	mov	_treg6 , # 8
    	shl	_sttos , # 18
    	jmp	# __1
    a_sd_shift_outlong
    \ send the bits in _sttos
    	mov	_treg6 , # 20
    __1
    \ hi bit to the carry flag
    	rcl	_sttos , # 1 wc
    \ set data out accordingly
    	muxc	outa , v_sd_di
    \ toggle clock
    	or	outa , v_sd_clk
    	andn	outa , v_sd_clk
    \ loop
    	djnz	_treg6 , # __1
    	andn	outa , v_sd_di
    	spop
    	jnext
    a_sd_shift_in
    	mov	_treg6 , # 8
    	jmp	# __3
    a_sd_shift_inlong
    	mov	_treg6 , # 20
    __3
    	spush
    	mov	_sttos , # 0
    	or	outa , v_sd_di
    __2
    \ clock high
    	or	outa , v_sd_clk
    \ read in bit
    	test	v_sd_do , ina wc
    	rcl _sttos , # 1
    \ clock low
    \ loop
    	djnz _treg6 , # __2
    	andn	outa , v_sd_di
    	jnext
    v_currentdir
    	0
    ;asm
    decimal
    I did load asm.f from eeprom.
    Next, copy/paste assembler_file
    to TeraTerm.
    Result is below;
    Prop0 Cog6 ok
    fl
    hex
    Prop0 Cog0 ok
    Prop0 Cog0 ok
    :asm
    v_sd_do
    0
    v_sd_di
    0
    CON:Prop0 Cog0 RESET - last status: 16 UNKNOWN ERROR
    Prop0 Cog0 ok
    Prop0 Cog6 ok
    Next, I tried same thing on QuickStart without SD-function.
    result is below;
    16B wconstant v_currentdir
    160 asmlabel a_sd_shift_inlong
    15E asmlabel a_sd_shift_in
    155 asmlabel a_sd_shift_outlong
    152 asmlabel a_sd_shift_out
    151 wconstant v_sd_clk
    150 wconstant v_sd_di
    14F wconstant v_sd_do
    lockdict variable def_014F 016C l, 014F l,
    0 l, 0 l, 0 l, A0FE1C08 l, 2CFE1018 l, 5C7C0156 l, A0FE1C20 l, 35FE1001 l, 70BFE950 l, 68BFE951 l,
    64BFE951 l, E4FE1D56 l, 64BFE950 l, 5CFDF0F1 l, 5C7C0075 l, A0FE1C08 l, 5C7C0161 l, A0FE1C20 l, 5CFDCEE0 l, A0FE1000 l,
    68BFE950 l, 68BFE951 l, 613E9FF2 l, 34FE1001 l, 64BFE951 l, E4FE1D64 l, 64BFE950 l, 5C7C0075 l, 0 l,
    freedict
    Prop0 Cog0 ok
    PropForth4.6 with SD-function cannot assemble asm-code.
    Is this normal?
    Or my PF4.6 with SD-function is strange?
    edited 2011-11-16 06:39
    OK Cas
    I think you may have a corrupt sdfs system,. I will start with a clean sdcard and save test.f in the usr partion then re load it from the sdcard. I will get back to you later today (my time)
    I will try to track down the fl issue too.
    Ron
    edited 2011-11-16 06:54
    Cas
    Cross post did not see your last post when I replied.
    Will get back to you
    edited 2011-11-16 09:23
    Cas
    Tested the fwrite and fload. See below the log, with my comments added.
    I cannot figure out why it is written to .partion-sys. The file should be written to the current
    directory IMO.
    I have not tested asm yet with sdfs loaded but I am thinking the code gets cleared by the sddriver sd_cogbufclr. Will check Ron
    Create this file greetings.f
    fl \ Starts here
    5 fwrite greetings.f
    : hi c" Hello Caskaz" .cstr cr cr ;
    ... \ Ends here
    paste it to Tera term
    Response from Forth
    fl
    Prop0 Cog0 ok
    Prop0 Cog6 ok
    Now......
    fload greetings.f
    Response from Forth
    Prop0 Cog0 ok
    Prop0 Cog0 ok
    Now enter
    hi
    Response from forth
    Hello Caskaz
    Prop0 Cog6 ok
    edited 2011-11-16 11:50
    Issues or does not work as expected
    1. fl will cause UNDEFINED WORD ... in a very short files
    consisting of only a one or two word definitions when using fwrite or fblock. Refer to Caskaz POST #96 #100
    2. Cannot write large files to sdcard. AKA hex 50 fwrite testfile
    the directory entry is written but no data. I used my edit_demo to test, which is a 6k text file.
    3. Can only fwrite to .partion-sys. Should be able to fwrite to current
    directory or to .partion-usr CasKaz POST #100
    edited 2011-11-17 07:47
    Hi Ron.
    It seems to be succcess.
    fl
    Prop0 Cog6 ok
    ls [enter]
    337 .partion-sys/
    130 .sdcardinfo
    136 .autousr.f
    133 .autoload.f
    Prop0 Cog6 ok
    I did copy/paste above code.
    -- Response from Forth
    fl
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    fload greetings.f [enter]
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    hi
    Response from forth
    Hello Caskaz
    Prop0 Cog6 ok
    ls [enter]
    337 .partion-sys/
    130 .sdcardinfo
    136 .autousr.f
    576 greeting.f
    133 .autoload.f
    Prop0 Cog6 ok
    But it cannot save in mountusr.
    Prop0 Cog6 ok
    mountusr [enter]
    Prop0 Cog6 ok
    ls [enter]
    65667 .partion-usr/
    Prop0 Cog6 ok
    cd .partion-usr/
    Prop0 Cog6 ok
    ls [enter]
    Prop0 Cog6 ok
    fl
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    ls [enter]
    65667 .partion-usr/
    Prop0 Cog6 ok
    cd .partion-usr/
    Prop0 Cog6 ok
    fl
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    ls [enter]
    Prop0 Cog6 ok
    edited 2011-11-17 08:18
    Hi Cas
    Good, you have success
    I cannot save to .partion-usr (mountusr) either. There are some other problems which you have mentioned. Read my post #107 to Prof.
    Ron
    I
    edited 2011-11-17 15:03
    Hi Ron.
    Thanks.
    And you can assemble assembler-file?
    If you can do it, maybe I have mistake when installing sdfs-system.
    edited 2011-11-17 18:09
    Hey guys
    Thanks for your investigation on these issues.
    Sal is still traveling and I'm cleaning up the bug list in preparation for 5.0 release.
    Hopefully these are (already) fixed in 5.0, I will make sure we have tests for these.
    Opened issues 73, 74, 75 for the issues described in post #107
    edited 2011-11-18 01:58
    Hi Cas, Prof
    No can do....assemble an assemble file
    I think forth runs out of room. I know hub is very tight, because I ran out of room recently with my editor program when I stopped using Ramblade and had to create a larger buffer.
    I have decided to stay with standard Prop board with just a SDcard for now., so I am playing with a virtual memory system for the SDcard.
    I have made a vram. f in .partion-sys. I am writing the driver in forth, but will need to convert is to asm later, so we need to be able asemble files to work with the sdcard driver.
    I should have used the sdfs system much earlier, but I have only been using the driver and have not had any problems with that.
    Hope Sal has got these issues covered.
    Ron
    edited 2011-11-23 08:12
    Hi.
    I wrote POV on QuickStart by spin.
    It scroll fonts inside ROM.
    Looking is fine although simple code.
    So, I translated it to PropForth.
    I also upload spin-file.
    240 x 400 - 46K
    240 x 400 - 31K
    240 x 400 - 33K
    edited 2011-11-23 09:14
    caskaz wrote: »
    I wrote POV on QuickStart by spin.So, I translated it to PropForth.
    You are the coolest!
    POV was the example used in a forth applications class many years ago. The class was given several LED, a hack-saw blade and a solenoid from and old door bell. The idea was to trigger the solenoid and make it strike the saw blade to get it oscillating. Then the LEDs were flashed to make a message.
    I guess all that's needed is a transistor, a saw-blade and a solenoid, and we will have the same demo.
    Very nice.
    edited 2011-11-23 10:00
    Hi Cas
    I agree with Prof, this is a great project.
    When can we have the code for the audio to go with the lyrics. ??
    Good Job, it just goes to show how effective the Forth tools can be.
    Ron
    edited 2011-11-30 14:47
    Why does my code work ??
    I do not understand! I pass the rendevous address to the driver from the word blink ( rendevous v_hadr COG!, the adr of rendevous is pushed onto the stack, then top of stack is
    popped and stored in cog4 adr at v_hadr )
    I would have thought that the driver at line (wrlong _treg4 , __3v_hadr ) would write the char back to the address of rendevous.
    In fact it puts the adr of the character in rendevous so in order to display the char I have to setup another level of indirection, see the word disp ( rendevous L@ W@ )
    The code does exactly what it is supposed to do, but I would have expected to achieve the same result with ( rendevous W@ )
    The program, blink (cog6) starts the driver in cog4 and outputs the character supplied by the driver
    The driver runs in Cog4 and blinks the LED on pin 16 then sets up the next char in the alphabet for output by cog6.
    I have a wc on the first line of my PASM code. It should not be there, but it does not affect the result
    fl
    hex
    variable rendevous
    variable datx
    161 wconstant v_hadr
    152 asmlabel a_tog
    151 wconstant v_char
    150 wconstant v_delay
    14F wconstant v_pin
    lockdict variable def_014F 0162 l, 014F l,
    00000010 l, 02625400 l, 00000061 l, A1FE1401 l, 2CBE154F l, A0BFED0A l, A0BE17F1 l, 80FE1680 l, A0BE1951 l, A0FE1A1A l,
    F8BE1750 l, 7CBFE90A l, F8BE1750 l, 78BFE90A l, 083E1961 l, 80FE1801 l, E4FE1B59 l, 5C7C0157 l, 0 l,
    freedict
    : lasm
    	4+ dup L@ swap
    	4+ swap over L@
    	dup coghere W!
    	do
    		4+ dup L@ cog,
    	loop
    	drop
    : start_blink def_014F lasm a_tog ;
    : disp dup  datx L@ <> if dup datx L! emit else drop then ;
    : blink rendevous v_hadr COG! c" start_blink" 4 cogx
      begin rendevous L@ W@ disp 0 until ;
    fl
    hex
    :asm
    v_pin
    10
    v_delay
    02625400
    v_char
    61
    a_tog
                  mov     _treg2 ,   # 1        wc
                  shl     _treg2 ,	v_pin
                  mov      dira ,   _treg2
                  mov     _treg3 ,     cnt
                  add     _treg3 ,   # 80
    __1
                  mov     _treg4 ,   v_char
                  mov     _treg5 ,     # 1a
    __2
                  waitcnt  _treg3 ,  v_delay
                  muxnz     outa ,   _treg2
                  muxz      outa ,   _treg2
                  add      _treg4 ,  # 1
                  djnz     _treg5 ,  # __2
                  jmp     # __1
    __3
    v_hadr
    0
    ;asm
    edited 2011-11-30 17:55
    Hi Ron.
    I tried QS with no SD-function and ptotoboard with SD-function.
    Your code work fine.
    By the way , you can assemble asm-code on Propforth4.6 with SD?
    I cannot assemble them on my protoboard(PF4.6) with SD.
    edited 2011-12-01 01:12
    Hi CasKaz
    I cannot assemble asm-code with SD-function. This is a problem
    Ok on my code. Yes I know it works but I do not understand why I need to write
    Why not this way ?? I do not understand ??
    begin rendevous L@ disp 0 until ;
    Ron
    edited 2011-12-01 13:41
    Hi Cas and others
    I have a revised the code I posted previously. Yes it did work but the code was wrong.
    rendevous was ignored in the previous version and the char was always written to hub adr 0
    Thats why it worked.
    This version now works correctly and can be run from any cog. The par register is required, because the pad area is
    different for each cog. The par points to the pad area assigned to the cog running blink.
    The char address is written to rendevous so there is a level of indirection, L@ W@ is required.
    rendevous is a dictionary word and common to all cogs. It will now hold the correct address for the char
    irresective of which cog is running blink.
    fl
    hex
    variable datx
    variable rendevous
    163 wconstant v_adr
    152 asmlabel a_tog
    14F wconstant v_pin
    lockdict variable def_014F 0164 l, 014F l,
    00000010 l, 02625400 l, 00000061 l, A0BE1DF0 l, 80FE1C40 l, A0FE1401 l, 2CBE154F l, A0BFED0A l, A0BE17F1 l, 80FE1680 l,
    A0BE1951 l, A0FE1A1A l, F8BE1750 l, 7CBFE90A l, F8BE1750 l, 78BFE90A l, 083E190E l, 80FE1801 l, E4FE1B5B l, 5C7C0159 l,
    00000002 l,
    freedict
    : lasm
    	4+ dup L@ swap
    	4+ swap over L@
    	dup coghere W!
    	do
    	    4+ dup L@ cog,
    	loop
    	drop
    : start_blink
      par COG@ 40 + rendevous L!
    : blink   c" start_blink" 4 cogx
    fl
    hex
    :asm
    v_pin
    10
    v_delay
    02625400
    v_char
    61
    a_tog
                  mov     _treg6 ,          par
                  add      _treg6 ,         # 40
                  mov     _treg2 ,          # 1
                  shl     _treg2 ,	v_pin
                  mov      dira ,            _treg2
                  mov     _treg3 ,           cnt
                  add     _treg3 ,           # 80
    __1
                  mov     _treg4 ,           v_char
                  mov     _treg5 ,           # 1a
    __2
                  muxnz     outa ,          _treg2
                  muxz      outa ,            _treg2
                  wrlong   _treg4 ,          _treg6
                  add      _treg4 ,            # 1
                  djnz     _treg5 ,           # __2
                  jmp     # __1
    __3
    v_adr
    2
    ;asm
    I need to write a few words on *Getting started with Propforth asm.* but rev 5.0 might be different again.
    Ron
  • TrapperBobTrapperBob Posts: 152
    edited 2011-12-01 14:57
    Hi Ron,
    I have been quietly following in the shadows. I am sure that enough of us out here could "learn" from any info you would be willing to spend the time to share on the topic of getting started with Propforth asm even if it does change in v5.0.
    edited 2011-12-01 15:28
    Hi ~Bob
    I have written a HOW TO but I need to read it again, before I post it. Too late tonight.
    Ron
    I
