QuickStart Whack-a-Mole Demo — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2011-11-27 18:00 in Propeller 1
Here's a QuickStart Whack-a-Mole demo.
Should call it Mole-Run because of the way it works.
This program uses a single COG.
I'll make a multiple COG version if I have time.
 * The Blue LED moles are eating up your QuickStart yard!
 * You must get rid of them!
 * Gameplay:
 * All living moles will run around the QuickStart burrow during
 * the game and you'll know they're alive by the dimly lit LEDs.
 * Sometimes a mole will pop up as brighly lit LED and you must
 * wack the mole pad to knock it out.
 * When the moles are gone, your QuickStart yard will celebrate!
  • bsnutbsnut Posts: 521
    edited 2011-11-27 03:08
    I will have to download your handy work and give a classic amusement park game a try. Since, I use to work for one as a full-time electrician.
  • ReinhardReinhard Posts: 489
    edited 2011-11-27 07:54
    Hi,
    my first question was: "What is a Quick Start"
    Now, I found the schematics for the board and can buld it.
    On the other hand, I can take the sourcecode and port it to a dsPIC Board,
    which have a huge LED and Botton Matrix.
    That is the charme of C, easy to port from one hardware to another, rather than each other programming language.
    I know this is not the focus for a gcc alphatest forum, but I must say it.
    best regards,
    Reinhard
    edited 2011-11-27 08:43
    Reinhard wrote: »
    Hi,
    Reinhard,
    I don't think there's any problems pointing out the portability of C here. I for one would be interested in seeing the code after you port it to compare the differences between the hardware specific details.
    As I understand it, well written C code should be able to go back and forth between platforms with a minimum of work. That's one of the things that makes propgcc (and other C platforms for the Prop) a win-win scenarios.
    edited 2011-11-27 09:50
    [QUOTE=mindrobots;1054813 I for one would be interested in seeing the code after you port it to compare the differences between the hardware specific details.
    [/QUOTE]
    Assume I have a board with the same wiring as Quick Start.
    The canditads for hardware abstraction layers are:
     * Set the LEDs to val
    void LEDOUT(int val)
        DIRA |= 0xff << 16;
        OUTA = (OUTA & ~(0xff<<16)) | (val<<16);
     * msleep makes the cog wait for about t milliseconds.
    void msleep(int t)
        waitcnt((CLKFREQ/1000)*t+CNT);
     * Get all buttons at once
     * Run this function from HUB if compiled for LMM.
    int getButtons()
        int n = 16;
        int result  = -1;
        int reading =  0;
        int pins = 0xFF;
        OUTA |= pins;               //output high to buttons
        while(n--)
            DIRA |= pins;           //output high to buttons
            DIRA ^= pins;           //switch to input
            reading = pins;
            msleep(2);              //wait for RC time
            reading &= INA;          //return button states
            result  &= reading;
        result = ~result & 0xFF;
        return result;
    But I am not really interest to port it.:smile:
  • jazzedjazzed Posts: 11,803
    edited 2011-11-27 10:30
    Obviously the QSWAM code was designed for Propeller and QuickStart board (and designed quickly); my time is limited so I must keep a reasonable focus.
    Making libraries that are compatible with some other popular environments could be useful to empower customers who may benefit from the Propeller's strengths (and enable greater Return on Assets/Equity for Parallax).
    What I've posted could be easily changed to run on other MCUs since it uses single COG. Reinhard has pointed out most items. Also srand(CNT) could be changed to srand(clock()) or left out entirely.
    I was thinking of adding 2 COGs: one to display the "runners" and another to detect the "whack". The intent of that would be to improve performance and showcase Propeller strengths.
    However if I add COGs the code would be even less portable (could be wrapped into a #ifdef __PROPELLER__). Encapsulating things into a function would make it easier for other MCUs and vanilla C compilers.
    So a key question arises: If one wants to make something worth more to potential customers, how do you extend their current code to allow using Propeller's strengths?
    BTW: I had planned a trip today. But it has been delayed a bit.
    edited 2011-11-27 10:54
    Hi,
    What I mean is the portability of C in general.
    Of course the propeller is a unique chip ( therefore I like them ).
    with 8 cpu's in parallel, other hardware goes to the limit and is not easy to port.
    Hope I have cleared this disaccord.
    best regards,
    Reinhard
    edited 2011-11-27 11:17
    No discord. I appreciate all of the preceding comments and contributions.
  • ersmithersmith Posts: 6,249
    edited 2011-11-27 12:34
    jazzed wrote: »
    You could use the pthreads library to start the other COGs -- that way the code would be portable to other MCUs. Of course it does mean you have to use LMM C code for the code you run in those other COGs, so there is a limitation, but it's not too awful.
    Eric
    edited 2011-11-27 14:50
    As a newbie to the QS board, can I ask how do you port this game onto the board as i'm only used to loading spin programs so far.
    skylight wrote: »
    Hi skylight. The Propeller-GCC tools have a loader for programming the QuickStart and many other Propeller boards. Today the Window's command environment is supported and IDE(s) will be used later. Please see propgcc.googlecode.com for downloads and wiki documents.
