Header bug?
blittled
I am building a library and have the following code
header file
This produces the error "unknown type name uint32_t" error when compiling with a file using #include in the header file for both functions, should this happen?
void PULSE(int pin, uint32_t duration)
int mask = 1 << pin;
DIRA |= mask;
OUTA |= mask;
DELAY(duration);
OUTA &= ~mask;
void DELAY(uint32_t duration)
uint32_t time;
time = CNT;
waitcnt(duration + time);
header file
void PULSE(int pin, uint32_t duration); void DELAY(uint32_t duration);
Did you include stdint.h? That is where uint32_t is defined.
#include "pulse.h" void main () { for(;;) { PULSE(0,10000); DELAY(20000); } }#include <propeller.h> #include "pulse.h" void PULSE(int pin, uint32_t duration) { int mask = 1 << pin; DIRA |= mask; OUTA |= mask; DELAY(duration); OUTA &= ~mask; } void DELAY(uint32_t duration) { uint32_t time; time = CNT; waitcnt(duration + time); }propeller-elf-gcc -o pulse.o -c pulse.c
propeller-elf-gcc -o pulse.elf pulse.o main.c
