Header bug? — Parallax Forums
Header bug?
blittledblittled Posts: 697
edited 2011-11-25 16:01 in Propeller 1
I am building a library and have the following code
void PULSE(int pin, uint32_t duration)
    int mask = 1 << pin;
    DIRA |= mask;
    OUTA |= mask;
    DELAY(duration);
    OUTA &= ~mask;
void DELAY(uint32_t duration)
    uint32_t time;
    time = CNT;
    waitcnt(duration + time);
header file
void PULSE(int pin, uint32_t duration);
void DELAY(uint32_t duration);
This produces the error "unknown type name uint32_t" error when compiling with a file using #include in the header file for both functions, should this happen?
    edited 2011-11-25 15:04
    blittled wrote: »
        DIRA |= mask;
        OUTA |= mask;
        DELAY(duration);
        OUTA &= ~mask;
        uint32_t time;
        time = CNT;
    header file
    Did you include stdint.h? That is where uint32_t is defined.
    #include <stdint.h>
  • ReinhardReinhard Posts: 489
    edited 2011-11-25 15:07
    Try:
    #include <stdint.h>
    #include "pulse.h"
    void main ()
        for(;;)
            PULSE(0,10000);
            DELAY(20000);
    #include <propeller.h>
    #include "pulse.h"
        DIRA |= mask;
        OUTA |= mask;
        DELAY(duration);
        OUTA &= ~mask;
        uint32_t time;
        time = CNT;
    propeller-elf-gcc -o pulse.o -c pulse.c
    propeller-elf-gcc -o pulse.elf pulse.o main.c
    edited 2011-11-25 15:08
    Ups, I see David was faster :smile:
  • blittledblittled Posts: 697
    Including the stdint.h did the trick! I'll have to learn what is in the libraries. Thanks!
