Merlin: Quickstart Robot Adapter — Parallax Forums
RaymanRayman Posts: 16,025
edited 2011-11-24 17:42 in Propeller 1
Here are some photos of our newest board, "Merlin".
The primary goal for this board is to allow the Quickstart board to drive the
"Magician" chassis from Sparkfun for $15. This lets you create a robot for only $65 in parts.
It also provides 1/2 of a Prop Platform's pins. This allows you to do things like connect our 4.3" and 3.5" touchscreen breakouts.
It also provides a spare eeprom socket, which can be used for our 3AD 3-axis accelerometer and also a gyro (coming soon) to make a 6DOF IMU.
Additionally, there is a 5V regulator on board and 4 three-pin headers for servos or 5V sensors.
It also has a place for an optional mini-breakout board.
    edited 2011-11-24 16:04
    Nice work Ray. Would you like to post some links here to the various components and a list of their prices. I am sure this would help others who have not been following the other threads.
  • RaymanRayman Posts: 16,025
    Cluso, yes, I should have mentioned the previous thread where we were exploring low cost options:
    http://forums.parallax.com/showthread.php?135486
    BTW: I think this board will also work well with the ArdBot chassis with "lobo" servos.
    By "lobo", I mean that we've modified a servo so that it only uses 2 wires and these 2 wires are connected directly to the motor and the circuit board is removed....
    Or, you could use the more regular "continous rotation" modified servos.
