low power display — Parallax Forums
low power display
mynet43mynet43 Posts: 644
edited 2011-11-23 22:46 in Propeller 1
Does anyone know of an ultra-low-power color LCD type display around 2.4" +/-?
The color display I'm using now works great. It's a Newhaven TFT 2.4" 320x240 pixels. But it uses more than 50 ma when the backlights are turned on. I'm using it in a battery powered device, so this is too much.
I found a somewhat similar monochrome display that uses less than 2 ma. It's an LCD type, without a backlight.
Are there any similar displays available in color?
Thank you for your help.
Jim
    edited 2011-11-23 19:00
    mynet43 wrote: »
    Jim
    Try ebay or craigs list and look for either garmin or the other one for old defective or castoff gps; hikers type, not car dash types. Find out which ones were color and could work w/out backlight or were fairly good on power. May be only monochrome works w/o backlight but I don't know for sure.
  • MagIO2MagIO2 Posts: 2,243
    Maybe you could also search for OLED displays in this size/resolution. Especially for dark backgrounds these save a lot of energy compared to LCD.
