Using Datalogger Demo code
I've read many of the threads on the 27937 Memory Stick Datalogger but haven't found the answers I'm looking for.
I have the Memory Stick Datalogger and have the Test and Demo codes working fine on a BS2.
I'd like to work this into my current BS2px-based Home Monitor project to log events with data and time stamp. It basically loops through 16 sensors and executes various LDC, PINK, DEBUG and V-Stamp commands based on if a sensor condition changed.
My questions concern the logic in where in a multi-slot program to place the various snippets of code. I see the following "functions" in the Parallax Demo code:
1. Initialize Transmit line
2. Sync Command Character
3. Switch To Short Command Mode
4. Prompt Device For Status
5. Purge
6. Open data file
7. Write data
8. Close data file
9. Get data
Which part(s) would I run just once at BS2px program load?
Which part(s) would need to execute during each loop?
Would I need a menu option (or loop exit) to initialize the USB stick?
Would I need a menu option (or loop exit) to eject the USB stick?
Would I need a menu option to open or close a data file?
I imagine I would go to a Sub Routine similar to the LCD, PINK, etc., when a condition changes. Would that just replace this part of the Demo with my data?
I think I can get my data organized and formatted to be written to the Memory Stick, I just don;t know which of these function are required where.
I appreciate any suggestions.
falcon
5. Purge
6. Open data file
7. Write data
8. Close data file
9. Get data
DEBUG "Open!", CR, CR, "Writing Data...", CR FOR counter = 1 TO NumSamples ' Number Of Samples To Log HIGH Sensor ' Charge Capacitor PAUSE 1 ' Wait 1 ms RCTIME Sensor, 1, result ' Measure Discharge Time DEBUG "Sample ", DEC5 counter, " of ", DEC5 NumSamples, " --> ", DEC5 result, CR ' Display Results SEROUT TX\CTS, Baud, [$08, $20, $00, $00, $00, $0D, CR, DEC5 counter, ",", DEC5 result, CR, LF, CR] PAUSE 500 ' Write Results/Delay GOSUB Get_Data ' Purge Receive Buffer NEXT
falcon
bsnut,
I appreciate the reply, but that doesn't really answer any of my specific questions. I plan to use the Demo code as written as much as possible but which parts would only be executed once at initialization (when power is applied to the circuit)? The project I'm working on uses 5 of the slots in a BS2p module. Slot 0 will be mostly initialization. After that the code will circulate through Slots 1 - 4 until Reset.
I understand that while my main code is running I will mostly use the "Write Data" snippet, but when/where would I insert the "Close Data File" snippet.
I see this Demo caode as about 9 different snippets/functions, but I do not understand the logic in 1. when each is to be run, and 2. how to place the individual snippets
I appreciate all replies and suggestions,
falcon
