I love it when a plan comes together — Parallax Forums
photomankcphotomankc Posts: 943
edited 2011-11-14 09:38 in General Discussion
Always nice when your hobbies manage to complement each other:
After messing with the Quickstart and Diligent Uno32 board I kept coming to the conclusion that it was a pain fighting the breadboards and cables and boards sliding around and pulling things loose. I wanted a way to hold the board and maybe some small development circuits and another board for coms testing that was easy to move from place to place. So I got the idea of a peg-board in MDF. Make little pins with hex standoffs attached and drill/tap them for 4-40's and layout a pattern that would allow me to get an Arduino or another Quickstart to mount onto it. Made the little pins last night on the lathe and turned them to be a *tight* fit in a drilled 3/16" hole. Then used the CNC mill to trim up the MDF and drill out the hole pattern on the left. The pattern was because I only had the hole layout for the Arduino, not the board dimensions so I wanted a little room to move it around. There is also a pattern to accept another QS board. So now I can trot upstairs with my little setup and sit in the livingroom and test code witout having to lug around a rats nest of loose boards.
It's always more work to do it than it seemed in our head planning it. Came out well though I think.
    edited 2011-11-13 10:54
    That's a nice little board, photomankc! That must make it much easier to move your workshop around, I just might have to make one of these myself!
  • $WMc%$WMc% Posts: 1,884
    edited 2011-11-13 13:56
    Great Idea photomankc...
    I have that rats nest on my bench now...I don't dare move anything until I get the drawing revised.
    This can become a real pain when I need to work on something else.(no bench space left)
    Thanks for sharing
    edited 2011-11-13 14:08
    Neat!
    I've always used thick cardboard to mount different boards together like this.
    (Just place a few M3 screws in the mountingholes on the boards, place it on the cardboard and apply force.. Then add a washer and nut on the other side)
    This also works with cardboard boxes... One that's 6 x 8" or larger, and maybe 2" deep is nice. Mount the boards on the inside, add a couple of baggies for components, a holder for AAs and suddenly a self-contained workbox.
    Doesn't look as neat, though.
  • Bill ChennaultBill Chennault Posts: 1,198
    edited 2011-11-13 14:21
    photomankc--
    Hey! Cool! Bring it over to my side of the line! (I'm in Piper.)
    --Bill
    edited 2011-11-13 23:29
    Wouldn't be too hard to setup with even just a drill and regular round standoffs if you can find a drill size that fit snugly into. I'll be happy if it gives other folks some ideas.
    Bill - it may be coming over the border a few days a week. My day job is at KU Med.
    edited 2011-11-14 05:26
    photomankc--
    It's a small world. My daughter did her post-doc at KU Med.
    I noticed your mill and lathe mentions. Do you belong to any of the home machinist's forums?
    --Bill
    edited 2011-11-14 08:11
    I do. Cnczone and homeshopmachinist. Same handle on those.
    photomankc--
    The Home Machinist forum for me. Same name. My pseudonym is seal killer. I think I am a member of the homeshopmachinist. I'll look for you over there.
    --Bill
