Is it recommended to have a capacitor on the VDD of the EEPROM? — Parallax Forums
Don MDon M Posts: 1,654
edited 2011-11-11 10:13 in Propeller 1
I was thinking I read somewhere that it is suggested to have one. In my design I'll have the EEPROM close by to the Prop and have 4 .1uF bypass caps around the Prop. Should I add a 1uF to the EEPROM also? A .1uF or both?
    edited 2011-11-10 17:53
    When I was a kid I got all my parts from old mainframe computers (worth millions in their day) and I noticed that every chip had its own 0.1uF capacitor, plus at the end of a row of chips (eg every 10 chips) there was a 10uF tantalum.
    Now, that was old-school TTL, but I've got in the habit of using a 0.1uF for each chip. So I put one one on the eeprom, and one on the ft232 etc etc. Maybe I end up using more 0.1uF caps than necessary, but they really are so cheap that I don't think it matters.
    edited 2011-11-10 19:39
    If the EEPROM's Vdd pin is proximal to one of the Prop's, there's nothing wrong with sharing bypass caps. The idea is to create a low-impedance (at high frequencies), distributed power "blanket" across the PCB, with the lowest-impedance points nearest the ICs' power connections. That's what the bypass caps attempt to accomplish.
  • plainsteveplainsteve Posts: 34
    edited 2011-11-11 09:47
    So, does the EEPROM qualify as high-frequency in this context?
    edited 2011-11-11 09:51
    A 1 Hz signal qualifies as high frequency if the rise and fall times are short enough, so yes.
  • BigFootBigFoot Posts: 259
    It is good to have a .1uF ceramic capacitor on each chip and across each connector where power
    leaves the board. You should also use 10 to 47uF tantalum cap around the board in several places
    on each power supply rail.
    This is called distributed capacitance and it makes for solid design in high volume production.
    The idea is when a chip needs to draw allot of current, say several outputs go high at once. There
    is capacitor close by to supply the initial current. Then after the outputs change state the current
    comes from the power supply bus.
