Looking for a water flow meter — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2011-11-09 10:31 in General Discussion
Hi Every One
I am at it agian
I want to use something that shows flow of water and use this with a
Basic Stamp
·I Google for a flow meter before and was not able to find any thing· that i
was willing to spend the money on
I·looking to spend up to $50.00 or maybe a liitle more·on this item
It only has to meter·1 to·5·GPM but it has read the flow
Can any one help me·with out me spending an arm and a leg on this
[noparse][[/noparse]Moderator added subject line]
··Thanks for any·idea.gif·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 3/20/2007 5:09:13 PM GMT
  • stamptrolstamptrol Posts: 1,731
    edited 2007-03-20 17:43
    For $50 I don't think you will have much choice.
    Try getting some sort of propeller into the water stream and count the blades going by a Hall effect sensor.
    Omega Engineering has some paddle wheel style with a pulse output but are well over $50.
    Try e-bay as well.
    If the delivery stream doesn't have to be under pressure, you can build a weir dam in a piece of rain gutter with a triangular slot in it. Measure the height of water as it builds up against the weir. More height means more flow.
    Good luck.
    Tom Sisk
    http://www.siskconsult.com
    edited 2007-03-20 17:48
    It's not $50, but it's under $100: webcat.ryanherco.com/products/490/120/210/490120210.cfm. And it would interface nicely with a BASIC Stamp.
    edited 2007-03-20 19:50
    ·Phil Pilgrim
    Thank You for the Web Link This will work and I will buy one and try it out
    This is a little more money than i want to spend on this flow meter but not
    overly priced
    When·i·was looking for·them before the ones that i saw where alot more money and where the ventera type flow meter
    Sam
  • steve_bsteve_b Posts: 1,563
    edited 2007-03-21 02:06
    What's the diameter of the pipe and what kind of flow do you expect?
    There would be an associated water pressure with a certain flow in a certain pipe.
    Do you just want to know set points? Could just use a water pressure switch (fairly cheap)....then set it for the pressure you're interested in.
    Steve
    "Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
    edited 2007-03-21 03:28
    Found this by Googling. www.allergybegone.com/flowpro-fpdm-200-digital-flow-meter.html
    - Stephen
  • Brian_BBrian_B Posts: 844
    edited 2007-03-21 03:32
    Heres what I use in my little concrete plant.
    ·www.mscdirect.com··· page 4547
    Thank's Brian
    www.truckwiz.com
    ·"Imagination is more important than knowledge..." ·· Albert Einstein
    edited 2007-03-21 21:31
    Franklin
    Thanks for the web link this just might work
    For this price i might just hack it to find out how it work
    ·I will have as much fun as these guy are having···· ·hop.gif···· jumpin.gif
    Brian Beckius
    Thanks for your reply but is alittle more than what i want to spend on this project
    steve_b
    Thank for your reply I would like to use 3/4 pvc pipe
    Sam
    edited 2007-04-10 03:25
    Franklin
    I bought two of these and I took one apart and it has a reed switch in it
    I am going to use a Parallax Melexis 90217 sensor to count the RPM's and chage it GPM
    I will have to order some of these to play with
    http://www.parallax.com/detail.asp?product_id=605-00005
    It has a nice wheel with a magnet and runs very freely well worth the $27.00 for it
    Thank You For finding this item for me
    Sam
    Post Edited (sam_sam_sam) : 4/10/2007 3:34:36 AM GMT
  • tercou1tercou1 Posts: 25
    edited 2011-11-08 16:58
    Here you go Sam: better late than never :smile:
    http://www.futurlec.com/FLOW25L0.shtml
    about 10 dolloars
    edited 2011-11-08 17:07
    I sent you a link for a water flow sensor not meter, sorry bout that
  • xanatosxanatos Posts: 1,120
    edited 2011-11-08 19:26
    Flow meters are notoriously expensive. You can try Great Plains Industries, they make fantastic units, but there is a great variation in prices. The one I just used for a client project was all stainless steel and cost almost $1k!!!
    tercou1 wrote: »
    about 10 dolloars
    Thank you for posting this. They have the exact sensor I wanted for a project a couple months ago. -Bookmarked-
