Hybred Boe Bot update
I finally got a little time to update my Hybred Boe Bot. The Dagu gripper assembly needed rework. I added a bigger servo on the gripper and changed to a lynxmotion servo bracket. I also added the Parallax USB wireless hub for remote programming. I was in a hurry and should have looked for a more powerful one, but can live with a 30' range for now. Beats chasing the bot, and plugging into the computer for program changes. It can also double as a host for a USB webcam. I raised the ping to make room for the gripper and it does work much better except for blind spots on the bottom. Be adding some IR sensors in the near future. Courous to see how much I can cram onto a Boe Bot. It is designed for alot. I can forsee running out of I/O soon. lol
What kind of items is it able to pick up with the grippers?
Did you have to drill new mounting holes in the gripper for your larger servo?
Does you bot run around autonomous? Is there a remote?
Very cool. Thanks for posting pictures.
Duane
