Is there such thing as "magnetic friction" and what controls it? — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2011-11-08 07:38 in General Discussion
Assume you have a large disk magnet acting as a table, and a smaller magnet that would be configured in a way that it would float effortlessly on top of the magnetic disk. Assume now that you could float the magnet and then spin it around the disk with a swipe of your hand, much like the "Quantum magnets" video posted on this forum a while back, which I'll post a link to shortly.
It was while watching that video that I had a thought, assuming you put the whole setup in a vacuum and gave it a spin, just how long would it spin before coming to a stop? And what force acting upon the smaller magnet would allow it to come to a stop? Wouldn't there have to be some sort of "magnetic friction" that would keep it from spinning indefinably?
I figured the forum could find some answers here.
Microcontrolled
  • BitsBits Posts: 414
    edited 2011-11-05 19:09
    Energy can not be created nor destroyed, so the answer is yes the magnets would stop. Conservation of energy laws apply here and I think its called magnetic damping.
    edited 2011-11-05 19:15
    Microcontrolled
    I may be not fully correct on this, but you would essentially have the equivalent of a linear motor. How long it would spin would be determined by the magnitude of eddy currents induced in the opposite magnet as spinning results in moving magnetic fields. The magnetic fields resulting from the eddy currents would be in opposition to the fields of the fixed and spinning magnets. The magnitude of the eddy currents would depend on a lot of factors. Otherwise the rules are likely still the same as all motors. Dynamic braking could be another term for magnetic friction.
    Frank
    edited 2011-11-05 19:17
    I think if you have a magnetic disk suspended above and spinning above a conductive disk, then the magnetic disk would induce electric eddies in the conductive disk, and those eddies would circulate through the electrical resistance of the conductive disk and convert the energy to heat, thus slowing things down. This is the concept of an eddy current brake.
    http://en.wikipedia.org/wiki/Eddy_current_brake
    But in the case you describe, the magnetic fields would repel each other and therefore, I guess, the magnetic field of each disk would be prevented from entering the opposing disk. So, as long as the fields are perfect and don't have some kind of distortion, I think they could, in theory, spin forever.
    But I'm just guessing on that.
    edited 2011-11-05 19:21
    First off there is no such thing as a complete vacuum, even in the deepest [bowls] *opps BALLS of space - no 100% vacuum, so this though experiment is already over. Second, nothing last forever due to the first.
    edited 2011-11-05 19:28
    Bits wrote: »
    ... so this though experiment is already over.....
    No it's not. I'm still thinking about it. And I can assure you, if there's a vacuum anywhere in any of the farthest bowls of space, it's in my thought processes.
    edited 2011-11-05 19:34
    So, if you had a vacuum in a bowl of space and you turned that upside-down, would the vacuum fall out?
    edited 2011-11-05 19:38
    PJ Allen wrote: »
    I'm guessing it depends on whether or not the bowl of space is in free fall. And how deep that bowl might be.
    edited 2011-11-05 19:40
    And I am guessing the bowl of space is located next to the plates of hell?
    edited 2011-11-05 19:59
    Would you be able to use Tupperware for these space bowls or would that "burp" thing disrupt some sort of freshness continuum?
    edited 2011-11-05 20:42
    Bits wrote: »
    ...the bowl of space is located next to the plates of hell?
    prince-william-commemorative-plate-woolworth-designs-prince-william-commemorative-plate-and-mug-QjzojS.jpg
    edited 2011-11-05 20:47
    OH MY, now that is the real deal. lol...
    edited 2011-11-05 22:59
    Even if you use a vacuum, a dampening effect would occur by the Earth's magnetic lines of force.
  • $WMc%$WMc% Posts: 1,884
    edited 2011-11-05 23:51
    Take a look at eddy currents.
    Some really cool stuff on magnets
    edited 2011-11-06 08:38
    Microcontrolled,
    I haven't seen an answer to your question yet.
    I'm not aware of any arrangement of magnets that will let you do this.
    Now if you want to talk about superconductors, that's different. The eddie currents others have mentioned is what allows the superconductor to levitate. The eddie currents in a superconductor don't cause any heat. There isn't any "magnetic friction". Just like there isn't "gravity friction". Planets seem content to keep moving around the sun for a very long time. Keeping something moving doesn't require energy.
    If you could move the magnetic track and superconductor into a vacuum, I'm pretty sure the superconductor would continue around the track as long as it remained in its superconducting state.
    Magnetic damping and eddie current brakes don't apply to superconductors the same as they do to normal conductors.
    Superconductors are strange, not just because they don't resist the flow of electricity. The way they interact with magnets isn't easily understood.
    I was hoping some expert on superconductors would enlighten us. I'm no expert. My knowledge of superconductors comes from a group presentation/paper I did in my modern physics class. I learned enough to know I'm not the only non-expert replying here.
    Duane
    edited 2011-11-06 12:26
    Thanks for all the answers so far, though it still seems unsettled upon. If the magnets are at opposing poles, than why would there be eddy currents in play with the magnet? Wouldn't that only occur if they were attracting?
    Duane Degn wrote: »
    I'm not aware of any arrangement of magnets that will let you do this....
    I'm thinking of something like this, though I didn't describe it very well initially.
    Red is north, grey is south. Sorry for the rough sketch.
    Tell me though, would this setup work, or not?
    960 x 540 - 223K
    edited 2011-11-06 12:58
    Whenever conductors are moving through magnetic fields eddy currents will be induced in them. Those eddy currents in turn will create a magnetic field of opposite polarity to the original wich will then oppose the motion. Also those eddy currents are subject to the resistance of the conductor and will generate heat. So energy is being sapped from the motion.
    In your case both ends of the system are magnets but of course they are also both condutors.
    This is your "magnetic friction". As an experiment try sliding a strong magnet accross the surface of an aluminium sheet. Or get hold of an old mechanical speedometer take it apart and see how that works.
    Have you ever played with magnets? That configuration in your picture would never be stable. As far as I know there is no such stable configuration.
    edited 2011-11-06 13:07
    I don't think that arrangement of magnets would be stable. I assume the top ring is held in place with some sort of structure. The small center magnet would try to flip over.
    You can have ringed magnets floating above one another, but it requires something to hold the top magnet in place. I've seen ring magnets with a dowel through the center of them. The dowel would cause significant friction.
    I only purely magnetic levitation (without electronics to continually monitor and adjust the field) I know of is with a top. The top was very difficult to adjust and would only spin in place. I still don't see a magnetic track arrangement without electronics or some sort of physical stabilization (which would cause friction).
    If only we had magnetic monopoles, all sort of interesting things could be done.
    Duane
    Edit: I hadn't seen Heater's post before I posted this reply. I agree with what he said.
    edited 2011-11-06 13:50
    Check out this video
    [video=youtube_share;Ws6AAhTw7RA]
    edited 2011-11-06 14:58
    Thats what I'm talking about
    Great video RON
    edited 2011-11-06 15:22
    Yes, amazing video.
    All demos I had seen (and performed) would levitate a small magnet over a superconducting disk.
    I assumed Microcontrolled was referring to this video in the OP.
    Very cool.
    Duane
    edited 2011-11-06 16:51
    @Ron Czapala: That was what I was referring to in my original post. What makes this special? Just what properties of superconductors make this work? Also, what is the disk made out of?
    @Duane Degn: Yes, I was assuming both the top and bottom magnet where secured by a wooden structure of some sort, but I didn't want it to obscure the rendering so I left it out.
  • David BDavid B Posts: 593
    edited 2011-11-06 17:41
    A magnet can be stably levitated with bismuth, a diamagnetic material.
    Google "bismuth levitation" to see some examples.
    edited 2011-11-06 18:20
    David B wrote: »
    See yet another reason to like the element of Bismuth.
    edited 2011-11-06 19:08
    Martin_H wrote: »
    You might also fall in love with pyrolytic carbon/graphite.
    Check it out on youtube, etc.
    http://www.youtube.com/watch?v=k9Zwc5U2kHE
    edited 2011-11-06 19:26
    What makes this special? .
    Superconductors
    The ability of superconductors to exactly counter magnetic fields. That's about the limit of my knownledge on the subject.
    I'm not sure if it's clear or not but the cold disk is the superconductor. The track is made up of magnets.
    High temperature superconductors (like the one in the video) are some sort of ceramic material. I think many have the element Yttrium in them. (I remember seeing the Y symbol in a formula.)
    edited 2011-11-06 19:43
    That's a great video Franklin.
    Now, what if the copper tube were a superconducting tube?
    I think a superconducting tube would completely stop the magnet from falling.
    Duane
  • TorTor Posts: 2,010
    edited 2011-11-07 00:01
    The most important difference with the figure in post #16 is that in the video there is only one magnet involved (and it's not the disk), in the figure in post #16 there are two magnets, and two magnets won't work - try it, they only want to flip so that they smack together.
    The disk in the video is a wafer of sapphire, and covered with a 1 micro-meter thin layer of so-called "high-temperature" yttrium-barium copper oxide superconductor (meaning that it superconducts when cooled with liquid nitrogen, iirc). Magnetic fields don't normally penetrate superconductors but because the layer is so thin some magnetic field lines will penetrate here and there and it's those that keep the wafer in place.
    So it's very far from trying to levitate two magnetic disks above each other - the magnetic attraction/repulsion isn't really the force involved here.
    All in my layman terms & understanding, of course - I'm not a physicist.
    -Tor
    EDIT: I found a great explanation from the guys behind this: http://www.quantumlevitation.com/levitation/The_physics.html
    There's a drawing at the bottom of the page which describes how the wafer is held in place.
    edited 2011-11-07 10:45
    Great link Tor
    1024 x 754 - 26K
    edited 2011-11-07 10:56
    Thank you Tor. That is very interesting.
    Duane
