PropGCC on MS Windows 7 - 64 bit - ver 0_1_5 — Parallax Forums
Bob Lawrence (VE1RLL)Bob Lawrence (VE1RLL) Posts: 1,720
edited 2011-11-03 19:12 in Propeller 1
I decided to try a quick test :)
Test 1:
1. Everything downloaded and unpacked fine.
2. Ran make for the demo's and all seems ok. Will test this more later with the examples once I have time to read the instructions for the hardware setup/ requirements / compatible boards etc.
3.I compiled and loaded the hello world example. It compiled fine and I got a message back saying that it loaded into prop ram fine. At that point the windows terminal program hung . I tried to re-run the test but it can't find the com port this time.I will re-boot the computer and get the com port back and try the examples again later tonight(time permitting)
Great so far.
  • jazzedjazzed Posts: 11,803
    edited 2011-11-03 07:02
    Great so far.
    Hi Bob.
    Looking at README_WINDOWS.txt I see a brief mention for stopping the terminal program.
    The hello.c example should show every step including how to exit the terminal program. Sorry about that.
    Please press ESC or Ctrl-C to exit the loader's terminal program.
    I think a terminal message should be added about this.
    We have noticed that if the COM port is in use, the loader will just hang until Ctrl-C.
    This problem is being tracked in propgcc issue #6 and we expect to fix it soon.
    --Steve
    edited 2011-11-03 07:33
    jazzed wrote: »
    Hi Bob.
    --Steve
    Good suggestion! The loader will now display the following message as it enters terminal mode:
    [ Entering terminal mode. Type ESC or Control-C to exit. ]
  • RonPRonP Posts: 384
    edited 2011-11-03 14:46
    I am also playing with propgcc not much of a command line guy but learning a lot. I was opening the Propeller Tool to find the COM#. Today I found if you type mode at the prompt you will get a list of connected devices. It doesn't say "Propeller connected to COM#"(wish it did) but if you run it before you plug in the Propeller and then after you can find out.
    Thought i'd share.
    -Ron
    edited 2011-11-03 18:43
    I have blink.c running on the basic breadboard setup from the PEK.
    Running Windows 7 64 with propgcc version 0_1_5.
    I followed these steps:
    - Installed the windows install as directed in README_WINDOWS.txt
    - Downloaded and copied grep.exe as directed in the "Grep missing!" thread.
    - Installed Cygwin as directed in the "PGCC on Win7 32-bit laptop" thread, but just copied cygpcre-0.dll from c:\cygwin\bin to c:\propgcc\bin instead of making changes to addpath.bat
    - Used mode as suggested above to find the COM port for my prop plug, was COM 3.
    - Created the blink.c file suggested in the README_WINDOW.txt file, I put it in c:\propgcc\testing\blink
    - Ran propeller-elf-gcc -o blink blink.c
    - Ran propeller-load -p com3 -b hub blink -r
    I have an grounded LED connected to P1 through a 100ohm resister and it is blinking very happily.
    Thanks to the GCC Team and those who tried it out and posted the tweaks needed to get it running.
    C.W.
    RonP wrote: »
    Thought i'd share.
    -Ron
    Thanks Ron! I forgot all about this command. Works great :)
    ctwardell wrote: »
    C.W.
    C.W. I just posted a new version that should fix all these grep/dll problems.
    The bonus in the package is Dave Hein's c3files SD Card test program.
    Other features have also been added. The package is about 40MB.
