pulsed diode laser range finder receiver
I am a M.Tech student. I am doing receiver signal processing but my signal level is very low means signal already merged inside the noise. I have tried to write vhdl code on pulse compression technique but not succeed.Kindly any one help me for this project and provide me the laser range finder vhdl or verilog source code. Analog part I have already completed.
Tell us about the details of your project and maybe we can help where you are stuck. There are some discussions on laser range finders here.
Otherwise, if you just want to download something without participating in a discussion, you might have to go with Google.
has a bunch on information discovered in the development process. It does not include vhdl code but has key information on addreessing the various technical difficulties that were overcome to get the unit working.
The key is DMTF (Dual Mixer Time Difference) and there is an experiment shown in http://forums.parallax.com/showthread.php?135563-Measure-the-speed-of-electricity...
