Application problem
Hello Parallax,
I have a problem with the basic stamp editor.
My computer is a new note book from Asus when I start the application,
this message appears:
Application:
1.1 Start Date : Tue, 1 Nov 2011 06:50:34 +0100
1.2 Name/Description: Stampw.exe - (BASIC Stamp Editor)
1.3 Version Number : 2.5.2.0
1.4 Parameters :
1.5 Compilation Date: Fri, 11 Mar 2011 18:04:48 +0100
1.6 Up Time : 34 seconds
Exception:
2.1 Date : Tue, 1 Nov 2011 06:51:09 +0100
2.2 Address : 005626A5
2.3 Module Name : Stampw.exe - (BASIC Stamp Editor)
2.4 Module Version: 2.5.2.0
2.5 Type : EAccessViolation
2.6 Message : Access violation at address 005626A5 in module 'Stampw.exe'. Read of address 00000008.
2.7 ID : 3DE1
2.8 Count : 1
2.9 Status : New
2.10 Note :
Active Controls:
4.1 Form Class : Ghost
4.2 Form Text : About
4.3 Control Class: TAboutForm
4.4 Control Text :
Computer:
5.2 Total Memory : 1014 Mb
5.3 Free Memory : 184 Mb
5.4 Total Disk : 100 Gb
5.5 Free Disk : 32,59 Gb
5.6 System Up Time: 1 day, 16 hours, 56 minutes, 15 seconds
5.7 Processor : Intel(R) Atom(TM) CPU N550 @ 1.50GHz
5.8 Display Mode : 1024 x 600, 32 bit
5.9 Display DPI : 96
5.10 Video Card : Intel(R) Graphics Media Accelerator 3150 (driver 8.14.10.2230 - RAM 256 MB)
5.11 Printer : Send To Microsoft OneNote 2010 Driver (driver 6.1.7601.17514)
Operating System:
6.1 Type : Microsoft Windows Vista
6.2 Build # : 7601
6.3 Update : Service Pack 1
6.4 Language: French
6.5 Charset : 0
Thanks for your comments .
Vadouzic
Application:
1.4 Parameters :
Exception:
2.7 ID : 3DE1
2.8 Count : 1
2.9 Status : New
2.10 Note :
Active Controls:
4.4 Control Text :
Computer:
Operating System:
6.2 Build # : 7601
6.5 Charset : 0
Vadouzic
I have the editor running under Vista without issues, although on a different machine. I also run the editor on an ASUS eeePC running XP.
I see that you have only a very tiny amount of Free Memory. Can you temporarily clear some RAM to see if that helps the issue?
Cheers,
Specs are as follows:
Lenovo Thinkpad T61p (Core2 Duo) T7700
Windows 7 Home Pro (32 bit) SP1
4 GB of RAM
Plenty of hard disk space.
Nothing plugged in at the time of install/run.
I do have the fingerprint reader, I wonder if that's an issue.
