Application problem — Parallax Forums
Application problem
vadouzicvadouzic Posts: 1
edited 2012-05-01 08:48 in General Discussion
Hello Parallax,
I have a problem with the basic stamp editor.
My computer is a new note book from Asus when I start the application,
this message appears:
Application:
1.1 Start Date : Tue, 1 Nov 2011 06:50:34 +0100
1.2 Name/Description: Stampw.exe - (BASIC Stamp Editor)
1.3 Version Number : 2.5.2.0
1.4 Parameters :
1.5 Compilation Date: Fri, 11 Mar 2011 18:04:48 +0100
1.6 Up Time : 34 seconds
Exception:
2.1 Date : Tue, 1 Nov 2011 06:51:09 +0100
2.2 Address : 005626A5
2.3 Module Name : Stampw.exe - (BASIC Stamp Editor)
2.4 Module Version: 2.5.2.0
2.5 Type : EAccessViolation
2.6 Message : Access violation at address 005626A5 in module 'Stampw.exe'. Read of address 00000008.
2.7 ID : 3DE1
2.8 Count : 1
2.9 Status : New
2.10 Note :
Active Controls:
4.1 Form Class : Ghost
4.2 Form Text : About
4.3 Control Class: TAboutForm
4.4 Control Text :
Computer:
5.2 Total Memory : 1014 Mb
5.3 Free Memory : 184 Mb
5.4 Total Disk : 100 Gb
5.5 Free Disk : 32,59 Gb
5.6 System Up Time: 1 day, 16 hours, 56 minutes, 15 seconds
5.7 Processor : Intel(R) Atom(TM) CPU N550 @ 1.50GHz
5.8 Display Mode : 1024 x 600, 32 bit
5.9 Display DPI : 96
5.10 Video Card : Intel(R) Graphics Media Accelerator 3150 (driver 8.14.10.2230 - RAM 256 MB)
5.11 Printer : Send To Microsoft OneNote 2010 Driver (driver 6.1.7601.17514)
Operating System:
6.1 Type : Microsoft Windows Vista
6.2 Build # : 7601
6.3 Update : Service Pack 1
6.4 Language: French
6.5 Charset : 0
Thanks for your comments .
Vadouzic
  • stamptrolstamptrol Posts: 1,731
    edited 2011-11-01 05:33
    Vadouzic,
    I have the editor running under Vista without issues, although on a different machine. I also run the editor on an ASUS eeePC running XP.
    I see that you have only a very tiny amount of Free Memory. Can you temporarily clear some RAM to see if that helps the issue?
    Cheers,
  • bpiltinbpiltin Posts: 5
    I am having this same problem. I tried uninstalling and reinstalling a bunch of times using different compatibility settings, etc... I also turned off antivirus software and anything else I thought could be a problem as far as the OS goes. My installation of Windows is relatively new and I believe it is clean as far as malware, viruses, etc. Please help as I am a teacher of a class where my students create BASIC Stamp projects. I have about 25 projects going in total and I can't afford to not help them debug their programs from my own computer... p.s. I used to have a Thinkpad T41p with XP running the editor and it worked fine. I'm not doing anything differently than before though as far as hardware is concerned... same BS2 board, same serial setup etc...
    Specs are as follows:
    Lenovo Thinkpad T61p (Core2 Duo) T7700
    Windows 7 Home Pro (32 bit) SP1
    4 GB of RAM
    Plenty of hard disk space.
    Nothing plugged in at the time of install/run.
    I do have the fingerprint reader, I wonder if that's an issue.
    764 x 574 - 113K
