Help Please. Loop doing strange things
I have been troubleshooting this code for some time now but to now avail. I hate to bother the forum with this but I'm at a standstill.
The code scans 4 push-buttons and starts a new method on a specified cog hen the conditions are met. The code works only when I comment out any of the cognew, coginit, and cogstop commands. The code works if I do everything in the same cog but I as soon as I try a new cog the loop will spit out a weird symbol and stop working altogether.
I have tried every way I could think of to start the "motorStep" method on another cog but I just can't get it to work. Thanks in advance for your help
PUB Main
{{Senses pins XPlus, XMinus, YPlus, YMinus logic state to control
outputs on pins XDir, XStep, YDir, YStep}}
Debug.Start(9600)
waitcnt(clkfreq/8 + cnt)
Debug.Str(String("Program is running..."))
Debug.NewLine
XCount := 50 'Set XCount variable to 50
YCount := 50 'Set YCount variable to 50
dira[XDir..XStep]~~ 'Set stepper control pins as inputs
dira[YDir..YStep]~~ 'Set stepper control pins as inputs
dira[0..3]~~ '-----Set test LED pins as inputs
dira[25..27]~~
!outa[0..3] '-----Test the LED outputs by cycling once at one Hz
!outa[25..27]
waitcnt(clkfreq/2 + cnt)
!outa[0..3]
!outa[25..27]
'End of initialization
repeat 'Loop scans input pins for current state
if (ina[XPlus] == 1) and (ina[XMinus] <> 1) and (XCount < XMAX) 'If button is depressed, without the other button being pressed and XCount is not at its max value, activate the corresponding method
'cogstop(1)
debug.str(String("Step X CW"))
debug.newline 'Corresponding method started in a new cog
'coginit(1, motorStep(CW, XStep), @Stack1)
'cognew(motorStep(CW, XStep), @Stack1)
XCount++
Debug.Dec(XCount)
Debug.NewLine
'waitcnt(clkfreq/5 + cnt)
elseif (ina[XMinus] == 1) and (ina[XPlus] <> 1) and (XCount > XMIN)
'cogstop(1)
debug.str(String("Step X CCW"))
debug.newline
'coginit(1, motorStep(CCW, XStep), @Stack1)
'cognew(motorStep(CCW, XStep), @Stack1)
XCount--
Debug.Dec(XCount)
Debug.NewLine
if (ina[YPlus] == 1) and (ina[YMinus] <> 1) and (YCount < YMAX)
'cogstop(2)
debug.str(String("Step Y CW"))
debug.newline
'coginit(2, motorStep(CW, YStep), @Stack2)
'cognew(motorStep(CW, YStep), @Stack2)
YCount++
Debug.Dec(YCount)
Debug.NewLine
elseif (ina[YMinus] == 1) and (ina[YPlus] <> 1) and (YCount > YMIN)
'cogstop(2)
debug.str(String("Step Y CCW"))
debug.newline
'coginit(2, motorStep(CCW, YStep), @Stack2)
'cognew(motorStep(CCW, YStep), @Stack2)
YCount--
Debug.Dec(YCount)
Debug.NewLine
I hope you realise that it does take some time to start a cog. It has to load the code from hub and then begin executing.
Since you have not posted all the code, it is hard to tell what is wrong. Likely it is what kuroneko has said.
