Is the C3 EOL ???
Is the C3 going to be discontinued? The latest Parallax catalog does not list the C3, and the Parallax store does not show when the, out of stock C3, will be replenished. At the new price level, maybe EOL is not such a bad thing, just would like to know for sure.
Ray
Ray
+1 (or maybe +2!)
I haven't even bought mine yet......hey, Yeah, that's it, they're EOL, if anyone wants to unload one cheap because of that.......
The C3 Full Kit is still available:
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/724/Default.aspx
I would say that until there is a formal announcement, assume that "out of stock" is simply that.
Ray
C3 is a key development platform.
IMHO it has the best feature set of all Parallax boards.
I would have done some things differently, but it's fine as is.
We currently have 37 C3 boards in stock (#32209). They were not showing up on the web as "available" because they were being allocated to C3 Full Kits (#32205). We removed the allocation (feel like you're inside Parallax yet with our lingo?) and in a few minutes #32209 will show up as being in stock at http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/C3/List/0/SortField/4/ProductID/721/Default.aspx. There are no plans to discontinue this product, so there is no need to worry. It's a core development system.
But if you want to worry like I do, we can collectively worry about the price going up if we can't figure out a way of reducing production costs. This is an expensive board to build, especially the way we're doing it.
Can you keep a secret? Take a look at our costs and retail on this product:
#32205 Propeller C3 Full Kit (cost 104.0560 and retails at 159.99)
#32209 Propeller C3 Board (cost 89.7381 and retails at 129.99)
We must have gone berserk to post our costs in public, right? No - many of you are product developers and you could reverse-engineer the costs on your own quite easily. At these margins we can forget ever recovering our non-recurring engineering costs. It's also important to understand that our average selling price is more like 75% of the retail price, so there is literally no profit in this product.
Thankfully our customers (thank you!) have kept our focus on other products and we've been too busy to give the C3 the attention it presently needs for cost reduction or price increase. I'll wait until the next build is finished to see if our ACE selective solder can lower our production costs. In the meantime, keep buying them and let's hope the price stays off our internal radar for a bit longer, or at least until our next fabrication run.
Sincerely,
Parallax is very good about planning and informing the public wwwwaaayyy ahead of time.
Want one? Digikey has 5 in stock:
http://search.digikey.com/us/en/products/32209/32209PAR-ND/2696574
But now that Ken has pull the magical strings, order 2 from Parallax.
would a semi assembled board be an option and offer a saving?
This is not exactly the same, but Xbee adapter boards are not assembled. C3 could be shipped with SMD parts soldered, and TH in a DIY kit.
I understand you are offering a top notch board and it would look "cheap", moreover you would have to assemble the DIY kit and have yet another part number to handle, but it would require little effort on the user side.
Massimo
Ken, as you guessed, many of us could work out your production costs but then again, why would we bother? I can estimate pretty accurately (if I wanted to), and besides, you let us in anyway. hehey.
Our job is to help promote the prop to get your volumes up so you can at least get some ROI back.
With SD and VGA and keyboard (perfect for the Super Star Trek example).
I kinda like the tabs too. The need to switch between the different SPI things and VGA things is a little too complex for my taste,
but Ross figured it out nicely for Catalia.
The other nice things is that they have ported over most of the Hydra games to run on it...
But I did totally rip off the design of the acrylic case for a project of my own. BTW, that flouroacrylic they have now that beams light out the edges of the material makes a case like the C3's look totally rad.
I never could figure out how you could initially afford to sell them for $79 and not lose your shirt on them... your numbers below make sense; so you get to keep your shirt
Bill
Rick & Nida Murray
RGM Enginering
