Did I build my motor controller properly?
I've been trying to build a motor controller, and here's a pic of my first attempt:
http://img.photobucket.com/albums/v229/yamoo/DSC00319.jpg
Here's the circuit it should be following:
http://img.photobucket.com/albums/v229/yamoo/motorcontroller.png
Alternate angles:
http://img.photobucket.com/albums/v229/yamoo/DSC00320.jpg
http://img.photobucket.com/albums/v229/yamoo/DSC00321.jpg
http://img.photobucket.com/albums/v229/yamoo/DSC00322.jpg
Nothing popped or melted yet. I've been running it for about 5 minutes, shutting it on & off several times.
I would upload the original schematics I'm following, but photobucket just errors whenever I try uploading the scan.
Does it look like the circuit is assembled properly?
Alternate angles:
Check out Nuts and Volts of Basic Stamps column #6 http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf
True, I meant to say that but forgot. Like in the last diagram in that N&V column, but with the motor where the relay is.
