NEW: Quick Adapter Module — Parallax Forums
Nick McClickNick McClick Posts: 1,003
edited 2011-10-20 11:25 in General Discussion
I just put this up this morning, the Quick Adapter Module is an expander for the QuickStart board - it adds;
  • Barrel Jack & Screw Terminal power connectors
  • Reset Switch
  • A LD1117V50 LDO regulator, which does about 1A @ 5V
  • An expansion spot for a second EEPROM.
It also breaks out the connections into a Propeller Platform compatible footprint so you can stack other modules on top.
The design is open source (of course), and diptrace design files are on the project page. I'm cleaning up the schematic right now and it will be up shortly, as well.
Project Page
Let me know what you think!
    edited 2011-10-18 11:43
    Nick,
    This is great! I have a bunch of QuickStart boards. This will make adding PP Modules easy. I also like the extra power.
    Thanks.
    Duane
    edited 2011-10-18 12:20
    Darn you, Nick....I mean Thank you, Nick!
    I need to order these when I get home! ...especially with the special deal!! I've been wanting to test how fast Jeff can ship something 30 miles or so!
    Keep it up and you'll end up making something like this with some D/A on it so you can mount an Arduino Shield onto a QuickStart! (consider it an UPGRADE to the Arduino Shield!)
  • Nick McClickNick McClick Posts: 1,003
    edited 2011-10-18 13:12
    Glad you guys like it! @mindrobots - I wanted to keep this one as inexpensive as possible, but if it's popular, I'll probably do an upgraded board, too.
  • Ken GraceyKen Gracey Posts: 7,416
    edited 2011-10-18 13:15
    Nick, a huge THANK YOU from Parallax!
    edited 2011-10-18 14:03
    Quo vadis?
    There are two pictures there, but neither shows the QAM connected to a QSB.
    edited 2011-10-18 14:10
    Ha! You're right - I'll snap a photo of the whole stack and put it up.
    edited 2011-10-18 14:36
    Two orders that came in while I was doing inventory tonight have already shipped!
    You guys will like these. It's a quick and easy build and makes the Quickstart boards compatible with soooo many existing products!
    OBC
    edited 2011-10-18 14:41
    @mindrobots:
    It might even be faster than you think! I usually skip over to Medina at least 3-4 times a month (Friday nights) to visit "The Exchange" and have dinner at that Mexican restaurant next door.
    A little coordination and you might be able to get things faster than almost anyone else.. (except Bryan) :)
    OBC
    edited 2011-10-18 16:55
    @PJ - here's a better photo with the QS board;
    And one in a stack,
    Standoffs are included.
    edited 2011-10-18 17:06
    I saw the solder nibs for the header, so I know that the pins are on the other side, and that it would mate up with the "star board" underneath it all, and I'm not deriding that or trying to be mean, but will the uninitiate "get" that?
    How about one more, of the QAM underside, showing the header?
  • tdlivingstdlivings Posts: 437
    edited 2011-10-18 17:28
    @OBC
    Great job shipping my order. Looking at the email you did it in about an hour. Thank's
    @NIck
    None of your pics show the QS board. I think you need one with it tilted on it's side showing the QS
    board on the bottom. All your picks give the impression the protoplus is the featured product.
    After I ordered I even took a second look thinking is this for the QS board or the protoplus and your USB board.
    I understand you want to show how the adapter makes your other boards like the protoplus work now with the
    QS board so keep all the present pics but have a new one showing a QS on the bottom as the first one so
    everyone gets the idea right out of the gate.
    Tom
  • tonyp12tonyp12 Posts: 1,951
    edited 2011-10-18 18:15
    I see that you leave /USB_PWR_EN not connected.
    I'm making a daughterboard for the Quickstart (custom project) that has a 5v Regulator that goes to Vin
    Should I connect the 5V to /USB_PWR_EN (goes to the gate of a P-chan mosfet)
    with a pull-down resistor so when you unplug the ac adapter
    I still have basic access to the prop with USB.
    edited 2011-10-19 10:07
    @pj - We provide a step-by-step assembly tutorial for beginners, it's linked on the top of the project page. Folks probably shouldn't try to build an electronics kit with just a photo of what it looks like completed.
    @tony - Take a quick look (here) - " USB power enable pin, inverted. Pulled to USB 5 V supply. Internally driven low after successful USB power negotiation. Can be externally driven low to force the USB power input to drive the QuickStart power supply, such as when powering from a USB charger."
    @tom- good feedback on the photos. I did revise the main photo to include the QS board, at least on the bottom - if you don't see it, your browser might be showing you a cached copy of the old image.
    edited 2011-10-19 15:22
    Here's a quick Halloween project to do with the kids which uses the Quick Module.
    http://www.gadgetgangster.com/news/54/507
    OBC
    edited 2011-10-20 09:36
    Just put up a quick walkthrough video, hope it helps;
    It's also on the project page.
    Now that is a complete presentation. :thumb:
