Servo Blocks Something new at ServoCity... — Parallax Forums
RonPRonP Posts: 384
edited 2011-10-19 09:52 in Robotics
Just noticed these Servo Blocks today thought some of you might find them interesting.
Ron
    edited 2011-10-17 20:22
    Those look both nicely conceived and nicely made. I'm not so sure about their patent-worthiness, though.
  • Ken GraceyKen Gracey Posts: 7,418
    edited 2011-10-17 22:39
    I also like the machining part and rigidity, or lack of slop in the total system.
    I can confirm that those little parts are expensive to manufacture. They're worth every penny ServoCity is charging for them.
    edited 2011-10-17 22:56
    'My thoughts, too, when I first saw them:
    1. Right-angle threaded holes in the hub plate, requiring an extra setup or a really fancy CNC.
    2. Servos splines, which have to be broached.*
    3. A lot of material to remove from the shaft hub.
    4. Bearing to press in.
    *Actually, they can't be broached, since they don't go all the way through, but terminate at a small-diameter hole for the screw that holds it on the shaft. I can't imagine how that part was even made.
  • PropabilityPropability Posts: 142
    edited 2011-10-18 11:29
    Since the part is made on a lathe then it's not that hard.
    http://www.youtube.com/watch?v=2zEz9CSoA3s&feature=related
    edited 2011-10-18 12:04
    Wow, very cool! I had no idea that could be done. Thanks for posting!
    edited 2011-10-18 12:37
    There is also a form of hobbing that could do it also. Since it's aluminum it wouldn't be that hard to displace such a small thing like the spline shape.
    I modified a common axle set just for the fun of it.
    768 x 576 - 68K
    768 x 576 - 79K
    edited 2011-10-19 06:34
    Lots of neat robots could be built out of those. Probably a robot arm would be the most cost and space effective usage.
    Martin_H wrote: »
    In progress!
