Servo Positioning
Hello to all
I have been trying out the servo and commands to it.
What I'm having problems with and not understanding why, is that when I position the servo lets say at 90 degrees and after it times out in the count instruction it wants to vary from that position.
Is this normal for servos?
Not for sure if it's the servo I have or is this the nature of the servo.
What I would like, is to position it to a location and and stay there until I come back and instruct it to change.
Gene
Gene
You issue the pulse, go do some other stuff, and repeat in time enough OR you buy a ServoPal (which is a "set it and forget it" device.)
PE - Get two. You can control two servos with one ServoPal, but you'll start thinking of stuff.
What I am curious about is that you mentioned the COUNT instruction. Can you attach your code?
