POV demo for the Demo board?
I recall there being an object that used the Built-on LEDs on the Demoboard for a simple POV display.
Does anyone still have a link to the thread or code?
ProccessingData...
ProccessingData...
[SIZE=2]''******************************************************************************** ''** Fun example uses the LED's on the demo board to display a bitmap ** ''** pattern stored in a data table ** ''******************************************************************************** '' Coded by Beau Schwabe (Parallax). ** ''******************************************************************************** '' '' Directions: '' Load the program. LED's will appear to ALL be on. '' Rapidly move the demo board back-n-forth. '' (unplug USB2SER connector first-grin '' '' '' Other options to this program would be to use an accelerometer '' to determine which direction/speed you are moving, and display '' an actual message forward or backward accordingly. _xinfreq = 5_000_000 'Set crystal frequency to 5 MHz _clkmode = xtal1 + pll16x 'wind it up to 80 MHz via a X16 PLL CON Rate = 50_000 'Set motion rate. VAR PUB Message | scan dira[16..23] := %11111111 'Make I/O's 16 to 23 OUTPUTs repeat 'Enter Endless Loop repeat scan from 0 to 26 'Create an offset index from 0 to 26 outa[16..23] := Propeller[scan] 'Lookup byte value in data table at offset 'scan' waitcnt(Rate + cnt) 'pause so we can see something DAT Propeller byte %00000000 byte %00010000 byte %00111000 byte %01111100 byte %11111110 byte %01111100 byte %00111000 byte %00010000 byte %00000000 byte %00000000 byte %11111111 byte %10000001 byte %10000001 byte %10000001 byte %11111111 byte %00000000 byte %00000000 byte %10000000 byte %01000000 byte %00110000 byte %00011000 byte %00000111 byte %00011000 byte %00110000 byte %01000000 byte %10000000 byte %00000000[/SIZE]
