Learning TV Remote using a Basic stamp
Hi,
Although I'm new to the Basic Stamp (Just got one last week). I am amazed at its power and versatility as well as all the projects readily available. One project that I would like to try building would be to make a true 'LEARNING' TV remote control where you would aim you present TV remote at it and it would record the IR stream feed to it. You could then replace that dog-chewed remote with your snazzy Basic Stamp remote! To my surprise, I cannot find any projects that have done this. Seems to me a project like that would already have been done if it were possible. Is there a technical reason that a Bs2 couldn't do it? If it has been done, could someone point me in the right direction?
Thanks in adanvce,
Jim
Thanks in adanvce,
Jim
You could start with an IR-Buddy (sold by Parallax) to test your idea on the widely used Philips RC5 code. When you have that working you can try to go to more exotic IR-codes.
The IR-buddy is easy to use and works reliable.
Regards and succes,
Klaus
Best,
Jim
I don't want to quash your enthusiasm for your newly discovered BASIC Stamp, because it is well founded, but aren't there already remotes on the market that do exactly what you want to do? You wouldn't be the first on this forum to want to reinvent the wheel because he (she) can do it with the Stamp, so more power to you. But if you want the outcome more than the process, I think it has already been done cheaper than you'll be able to do it with the Stamp when you factor in time and parts.
Here's one for $50.
www.x10.com/products/x10_ur74a.htm
Work:· Clemensb@otc.edu
Good Stuff on my Blog: http://theDeadBug.journalspace.com
· This sounds like an interesting application.· I know of a handicapped student who is trying to use a TV remote to create a remote-controlled lawnmower.· I haven't had the time to figure out the IR coding of the remote control.· But I sure would appreciate it if you would please post a summary of your results.· Also, please include the cost of the·decoder.
thanks,
agentile
Your right, I can do it faster by simply buying one. I've been there and done that. The kind of remote that I need would be the true learning remote. The kind that you point your old remote to and feed it the pulse. From what I have seen they tend to go for $80.00 and up! I've already spent up to $35.00 for the universal remotes. They all work fine for most functions but none of them will do all the functions like picture in picture and other specialized function that the original did before 'Evil Dog' got to it. Anyway, I definitely don't want to loose a $100.00 remote to monster dog. I don't know if I can even do it but it would be a useful project that I others might be able to use. If I can get anywhere I'll post my results here. Thank you for the link. I have one of those remotes from X10.
Jim
I think that if I were going to build a remote controlled lawnmower I would use RF signals instead of IR (infrared). With RF (radio Frequency) you don't have to constantly point a remote at the mower. Also, when the mower turns you will loose communication. If I were to control a mower with RF I would probably consider a low-end radio controlled airplane kit. It comes with a transmitter and some servomotors. That probably doesn't answer your question though. As my project evolves (if it evolves) I'll post my progress here and I'll let you know the cost of the decoder I end up with.
Jim
I'm reinventing wheels all the time and they allways turn out to be more expensive than what I can buy, most problems have been solved before, you know. But it's big fun and it's big learning to do these things myself, that's why I keep doing it
I started programming on a ZX81 in basic (actually on an IBM 370 in ALGOL
But it's big FUN !!!
Regards and succes,
Klaus
here is a link to info on protocols and theory of ir remotes.
www.xs4all.nl/~sbp/knowledge/ir/ir.htm
Rick
Jack
That link will be a big help on my project!
Jim
RE: Building Learning TV Remote Baby step #1
1. Disassembled an old broken TV remote and removed IR LED
a. Installed onto breadboard and wired it like a standard LED
b. Verified it’s still alive and well by looking at it while lit through my digital camera. (Through the camera you can actually see if its on or off) Found that out from the link that Rick posted.
2. Scrounged up an IR receiver from a broken VCR we had in the attic.
a. It took a little guesswork but I got it to work!
3. I downloaded an oscilloscope program that works from the mike input of your sound card from this link http://www.electronics-lab.com/downloads/pc/002/index.html
a. I built a probe to verify that it worked by removing the microphone from an old mike and grounding the black wire and hooking the red wire to the output of the IR receiver.
b. I took a working remote and aimed it at the receiver and pushed a button. I can clearly see the pulses.
4. I then hooked it up to the basic stamp and wrote a little program that scanned the input of one of the lines. When I run it in a loop I can see ones and '0's flying by when the remote is sending data to it.
Next Step:
Now I need to figure out how to capture that pulse in a variable and store that in the EPROM.
I never used it before but I think serin might be the answer. Are there any maven’s out there that might have some advice? I would prefer to avoid building a lot of supporting hardware if I can. Seems to me capturing the pulse could be done with a software routine.
Any pointers are greatly appreciated,
Jim
HighLen VAR WORD
LowLen VAR WORD
HighHold VAR WORD
LowHold VAR WORD
IR_Decoder VAR IN0 ' Pin zero
INPUT 0
MAIN:
IF IR_Decoder = 0 THEN
GOSUB GetBits
HighHold = HighLen
LowHold = LowLen
END IF
GOTO MAIN
GetBits: ' You'll have to experiment to find how long each 'while' loop increment takes.
HighLen = 0
LowLen = 0
WHILE IR_Decoder = 0
LowLen = LowLen + 1
WEND
WHILE IR_Decoder = 1
HighLen = HighLen + 1
WEND
RETURN
I can't wait to try it out! You must be claravoyant. How did you know I was using pin '0' as an input?
http://www.parallax.com/dl/docs/prod/sic/IRRemoteforBoebot.pdf
Hey Basic Jim, can you talk more about the sound card based oscilloscope?? how you made the probes? maximum voltage that the sound card support, etc??
I only used the O'scope to see the wave pulse. I wouldn't recomend using it for any high current or high voltage apps. It looks to me like it is ment to be used for noise waveforms. All I did to build the probe was to pulg in an old mic from a headset that I had and after I verified my voice was registering on the scope I unpluged it and chopped the mic part off. I connected the black wire to my test circuit ground and used alligator clips to connect to the reciever output through a 10 k resister. I would recomend a high ohmage resistor and reduce the resistor until you get the amplitude you want. I realize this isn't a great setup but it did give me what I was looking for. The only thing I wish the scope could do is measure DC voltages. but, the price is good! Total cost 1 crappy mike that would have been scraped anyway.
Jim
As far as the mic input....I think it clips at a less voltage....
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
·· You are correct, as I was saying in the other thread (There are 2?) that line level audio signals are usually 1V P-P, although some car audio systems go up to 2V.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Thanks!
$6 makes more sense than using a $50 stamp! But if you're really determined to use a stamp, you could use an oscilloscope and a 38 kHz IR receiver module and examine the various patterns. You could manually code the output for as many keys as the Stamp memory will allow.
Have a look at the Parallax apps for IR to learn about the Sony SIRC protocol. Here's an older one : http://www.jameco.com/Jameco/Products/ProdDS/282933APP.pdf
http://forums.parallax.com/showthread.php?102444-Infrared-Remote-controll-Help&highlight=build+IR+remote+control
http://forums.parallax.com/showthread.php?107497-Ir-remote&p=759751
