PropBasic & Viewport - Page 4 — Parallax Forums
124»
  • BeanBean Posts: 8,129
    edited 2011-10-03 04:04
    'A' will be compiled as a comment.
    "A\000" would work for a single character string (but is not pretty).
    I'll look into the spin CASE statement to see if I can implement something like it.
    Bean
  • HannoHanno Posts: 1,130
    edited 2011-10-04 00:02
    Hi Bean,
    Years ago I played with Borland's Turbo Pascal- Prolog was also lots of fun! I don't have any experience with Delphi.
    I now program in C# and have had good success using Mono to support OSX and Linux. I really like the PropBasic interface (especially the .err file) - I'd prefer to keep things simple where ViewPort passes files and arguments to PropBasic and gets back files- I don't think we need a closer integration- at least for now. Some quick searching reveals that Delphi can output binaries that can run on the Mono CLR- do you know anything about that? Or on outputting binaries for OSX/Linux? Do you mind if I include the PropBasic compiler in the ViewPort installer?
    Hanno
    edited 2011-10-04 03:47
    Hanno wrote: »
    I don't think Delphi will work on Mono because it is not a .net language. But I could be wrong about that...
    I don't have a Mac or Linux box, but if I did I would use "Free Pascal"/Lazarus www.freepascal.org to compile for them.
    Hanno wrote: »
    I do not mind at all. I would be greatful. The more people using PropBasic the better.
    P.S. If you want to try compiling with free pascal just shoot me a PM with an e-mail address and I'll send you the source code.
    I'm downloading freepascal right now. I'll see if there are any changes needed to cross-compile.
    Bean
  • FriedVFriedV Posts: 77
    edited 2011-10-04 05:30
    Hello,
    where does PropBasic look for LOAD and INCLUDE files?
    Only in the same directory as the source is?
    It would be nice to be able to specify a lib/asm directory, perhaps as a switch?
    Cheers, Friedrich
  • SapiehaSapieha Posts: 2,964
    edited 2011-10-04 06:16
    Hi Bean
    I do not mind at all. I would be grateful. The more people using PropBasic the better.
    You need say --> It is Very Good if people Have 2 Very Good programs Married to use !!!
    edited 2011-10-05 06:42
    FriedV wrote: »
    Hello,
    Cheers, Friedrich
    That sounds like a good idea. I'll look into it.
    Here is a demo program that shows the speed of PropBasic. It draws random lines on the video feed. It avergaes about 8300-8400 lines per second.
    ' Viewport video demo showing speed of PropBasic
    ' Draws random lines shows how many lines per second(lps) are drawn
    DEVICE P8X32A, XTAL1, PLL16X
    FREQ 80_000_000
    vidBuffer HUB BYTE(19200) = 0
    PROGRAM Start
    Plot     SUB 2 ' X, Y
    Line     SUB 4 ' X1, Y1, X2, Y2
    x1      VAR LONG
    y1      VAR LONG
    x2      VAR LONG
    y2      VAR LONG
    color   VAR LONG
    rand    VAR LONG
    lineCnt VAR LONG
    tempCnt VAR LONG
    lps     VAR LONG
    temp    VAR LONG
    WATCH lps
    Start:
      VPVideo vidBuffer
      DO
        lineCnt = 0
        tempCnt = cnt
        DO
          RANDOM rand, x1
          x1 = x1 AND 159
          RANDOM rand, y1
          y1 = y1 AND 119
          RANDOM rand, x2
          x2 = x2 AND 159
          RANDOM rand, y2
          y2 = y2 AND 119
          RANDOM rand, color
          color = color AND 252
          Line x1, y1, x2, y2
          INC lineCnt
          temp = cnt - tempCnt
        LOOP UNTIL temp >= 80_000_000
        lps = lineCnt
      LOOP
    END
    SUB Plot ' X, Y
      __param2 = __param2 * 160
      __param1 = __param1 + __param2
      WRBYTE vidBuffer(__param1), color
    ENDSUB
    SUB Line ' xStart, yStart, xEnd, yEnd
    _x1     VAR LONG
    _y1     VAR LONG
    _x2     VAR LONG
    _y2     VAR LONG
    _dirX   VAR LONG
    _dirY   VAR LONG
    _deltaX VAR LONG
    _deltaY VAR LONG
    _temp   VAR LONG
      _x1 = __param1
      _y1 = __param2
      _x2 = __param3
      _y2 = __param4
      _deltaX = _x2 - _x1
      _dirX = sgn _deltaX
      _deltaX = abs _deltaX
      _deltaY = _y2 - _y1
      _dirY = sgn _deltaY
      _deltaY = abs _deltaY
      IF _deltaX > _deltaY THEN
        ' Horz line
        _temp = _deltaX / 2
        DO
          Plot _x1, _y1
          IF _x1 = _x2 THEN EXIT
          _temp = _temp - _deltaY
          IF _temp < 0 THEN
            _temp = _temp + _deltaX
            _y1 = _y1 + _dirY
          ENDIF
          _x1 = _x1 + _dirX
        LOOP
      ELSE
        ' Vert line
        _temp = _deltaY / 2
        DO
          Plot _x1, _y1
          IF _y1 = _y2 THEN EXIT
          _temp = _temp - _deltaX
          IF _temp < 0 THEN
            _temp = _temp + _deltaY
            _x1 = _x1 + _dirX
          ENDIF
          _y1 = _y1 + _dirY
        LOOP
      ENDIF
    ENDSUB
    Bean
    edited 2011-10-05 10:08
    Here is an optimized line program. This one gets almost 15,000 lines per second.
    FREQ 80_000_000
    PROGRAM Start
    Plot     SUB 2 ' X, Y
    x1      VAR LONG
    y1      VAR LONG
    x2      VAR LONG
    y2      VAR LONG
    color   VAR LONG
    rand    VAR LONG
    lineCnt VAR LONG
    tempCnt VAR LONG
    lps     VAR LONG
    temp    VAR LONG
    WATCH lps
    Start:
      VPVideo vidBuffer
      DO
        lineCnt = 0
        tempCnt = cnt
        DO
          RANDOM rand, x1
          x1 = x1 AND 159
          RANDOM rand, y1
          y1 = y1 AND 119
          RANDOM rand, x2
          x2 = x2 AND 159
          RANDOM rand, y2
          y2 = y2 AND 119
          RANDOM rand, color
          Line x1, y1, x2, y2
          INC lineCnt
        lps = lineCnt
      LOOP
    END
    _x1     VAR __param1
    _y1     VAR __param2
    _x2     VAR __param3
    _y2     VAR __param4
    _dirX   VAR LONG
    _dirY   VAR LONG
    _deltaX VAR LONG
    _deltaY VAR LONG
    _temp   VAR LONG
    _addr   VAR LONG ' Current pixel address
      _deltaX = _x2 - _x1
      _dirX = sgn _deltaX
      _deltaY = _y2 - _y1
      _dirY = sgn _deltaY
      _dirY = _dirY * 160
      ' Set _addr to starting pixel address
      _addr = GETADDR vidBuffer
      _temp = _y1 * 160
      INC _addr, _temp
      INC _addr, _x1
        ' Horz line
        _x2 = _deltaX
        _temp = _deltaX / 2
    HLine:
          WRBYTE _addr, color ' Plot pixel
          IF _temp < 0 THEN
            _addr = _addr + _dirY ' Adjust pixel address for change in Y
          ENDIF
          _addr = _addr + _dirX ' Adjust pixel address for change in X
        DJNZ _x2,Hline
      ELSE
        ' Vert line or single point
        IF _deltaY <> 0 THEN
          _y2 = _deltaY
          _temp = _deltaY / 2
    VLine:
            IF _temp < 0 THEN
            ENDIF
          DJNZ _y2,VLine
        ELSE
          WRBYTE _addr, color ' Plot single point line
        ENDIF
      ENDIF
    ENDSUB
    Bean
  • w4fejw4fej Posts: 264
    edited 2011-10-05 13:45
    @Bean ROFLMAO!!
    Husband: If I won the lottery would you take half and leave me ?
    Wife: Of course not !
    Husband: How about if I throw in the house too ?
    I had a similar conversation with my ex-wife when she Said: "It's me or that $10,000 worth of flight simulator equipment you bought"!. I'm sure gonna miss her.....
    Mike B.
    edited 2011-10-12 03:33
    Nice job on the optimized line drawing!
    I've been busy on some "modern" features for ViewPort- will make PropBasic much more fun! Will be revealed soon.
    Does PropBasic do terminal IO yet? In current ViewPort you should use the 'terminal.spin' object to input/output bytes, strings, numbers... I'm improving that so you no won't need to "share" two longs for sending/receiving data- all ViewPort programs will have basic tx/rx/rxavailable functionality available. Here's a sample echo program:
    con
     clkfreq
     clkmode
    obj
     vp:"conduit"
    pub echo
     vp.share(0,0) 'start conduit- no need to share anything
     repeat
       vp.tx(vp.rx)
    I thought I ran across some Delphi tool that compiled delphi code to .net/mono bytecode- but I can't find it now... At some point osx and linux binaries would be nice. I'll include PropBasic in next installer with references to you and your website.
    Hanno
    edited 2011-10-12 05:07
    Hanno,
    Thanks. I don't have the website anymore though.
    I'm about to run out on my trial. Could you give me a license code ?
    I just posted version 1.25 in this thread http://forums.parallax.com/showthread.php?135098-PropBasic-Bug
    Bean
  • SandfireSandfire Posts: 32
    edited 2011-10-17 09:00
    Hanno wrote: »
    Hanno
    How is this coming Hanno?
    edited 2011-10-17 20:42
    Hi Sandfire,
    I see this is your first post! Welcome to the Propeller community. We have school holidays right now so I'm not making as much progress as I'd like. I did put up some screenshots of OPA- the open protocol analyzer- but I want to wait until I have things nicely working before announcing the results of my current effort.
    Hanno
    edited 2011-10-19 11:59
    Hanno wrote: »
    Hi Sandfire,
    Hanno
    Thanks Hanno.
    Well, I am really looking forward to seeing what you've been working on.
    I won't ask any questions and just be patient.
    Enjoy the time with your kids.
  • skynuggetskynugget Posts: 172
    edited 2011-11-05 06:34
    hey hanno and bean,
    i have been trying to watch a word value read from a data table. the value of tmp is erratic and never matches the values in table, am i doing this right? thanks!
    FREQ 80_000_000
    Table WDATA 1500,2000,2200,1500,1500,1500,1500,1500
    tmp  VAR LONG
    idx   var long
    watch tmp
    watch idx
    PROGRAM Start
    Start:
      FOR idx = 0 to 8
        RDWORD table(idx), tmp
        pause 500
      NEXT
    GOTO START
    END
    edited 2011-11-05 13:52
    Hi Skynugget,
    I confirmed that your table data don't show up. I think it's Bean's issue- since the spin file doesn't seem to contain the data.
    Hanno
    edited 2011-11-05 17:34
    thanks hanno, i thought i was going crazy for a while there.
    edited 2011-11-06 11:46
    I'll look into this as soon as I can, probably Monday or Tuesday.
    Bean
    edited 2011-11-06 15:03
    thanks bean
    edited 2011-11-07 04:35
    Skynugget,
    I have fixed the problem (Thanks for finding it).
    I have started a new thread to keep the latest version of PropBasic for Viewport in.
    You can download version 1.26 from here http://forums.parallax.com/showthread.php?135678
    Let me know if this does indeed fix the issue.
    Bean
    edited 2011-11-07 04:54
    so far so fixed! I wish i knew more about pasm so i could be more help. thanks again!
  • simonlsimonl Posts: 866
    edited 2012-06-10 17:17
    Hi Bean,
    Have I just found a bug, or am I trying to do something that won't work?:
    rxHead    HUB Byte = 0
    rxTail    HUB Byte = 0
    rxBuffer  HUB Byte( 64 ) = 0
    idx       VAR  Long
    FOR idx = rxHead TO rxTail
      TX_STR rxBuffer(idx)
    NEXT
    When I try to run this (via ViewPort) I get a compile error: INVALID PARAMETER "rxTail".
    I tried swapping rxTail and rxHead, but that gives "rxHead" as the invalid parameter. Does this mean I can't have two variables in the FOR loop?
    edited 2012-06-11 06:17
    Simon,
    HUB variables cannot be used as a VAR. They are simply for storage to be used with RDxxxx and WRxxxx.
    Change rxHead and rxTail to VAR LONG and it will work.
    Bean
    edited 2012-06-12 10:40
    Arrgh! OK, I'll get the hang of this eventually. Thanks Bean, the following works (I need to keep the HUB variables because they're fed from another cog.):
    rxHead    HUB Byte = 0
    rxTail    HUB Byte = 0
    idx       VAR  Long
    temp  VAR Long
    hd  VAR Long
    tl  VAR Long
    FOR idx = hd TO tl
    [B]  temp = rxBuffer(idx)
      TX_STR temp
    [/B]NEXT
  • 10Sector10Sector Posts: 3
    edited 2012-07-10 23:46
    I've just set up propbasic and viewport (4.7.7 latest beta). Do breakpoints work with prop basic? It's sure handy to be able to step through a program. Thanks
  • MicksterMickster Posts: 2,859
    edited 2012-10-12 13:09
    Okay, I'm really confused. I downloaded VP from Hanno's site and paid my $89. Now I want to use PropBASIC but find that my new VP is V 4.5 [something] and that PropBASIC requires V 4.6.7(?)
    So, I go to my Help menu in VP and select 'Check for updates' and, sure enough, I already get an update....but only to V4.6.2????? And the post previous to this discusses 4.7.7???
    What am I missing here?
    Mickster
    edited 2012-10-12 13:45
