BOE-Bot not detected on Mac computer using USB
I bought a boe bot robot kit for one of my classes that I am taking and own a mac, but when I connect the USB cord in, the MacBS2 editing system does not make the connection between the stamp and does not identify it. I have already downloaded the new drivers off of the FTDI website and it is still giving me these problems. So if anyone can help me ASAP I would greatly appreciate it.
Check your power source. Try another USB cable. Try reinstalling the FTDI driver and make sure the BoeBot isn't plugged in when you do so.
MacBS2 won't work under MacOS Lion, but it's always worked fine for me on a variety of Macs and versions of MacOS prior to Lion.
You need to make sure to the select usbserial-A1009ZSV, from the Serial Port option, in the drop-down menu Stamp.
See the screen shot below:
Once I did this, I got the "happy face" in the MacBS2 console.
Of course, this was after I trashed my existing FTDI Driver (explained by Jessica Uelmen here), restart, installed new FTDI driver, restart, launch MacBS2.
I am looking forward to getting started!
Yep. That's how the FTDI adapters show up. The "A1009ZSV" may be different since it's the id of the specific adapter that you have, but the general format of the menu item is the same. Have fun with the Stamp.
