PropBasic & Viewport - Page 3 — Parallax Forums
13
  • HannoHanno Posts: 1,130
    edited 2011-09-27 12:39
    Hi Bean,
    Nice job on using the @@@ operator and writing "register" values to hub when they're changed. Yes, "load" will call propbasic without the "/vp" option- hopefully later today. I'll also check up on strings. Good job with the array.
    Hanno
  • BeanBean Posts: 8,129
    edited 2011-09-27 16:46
    Hanno,
    Here is a demo program and the generated .spin file. You'll see the Viewport configuration is now at the very end of the .spin file.
    DEVICE P8X32A, XTAL1, PLL16X
    FREQ 80_000_000
    PROGRAM Start
    temp  VAR LONG
    Hub1  HUB LONG(20)
    Hub2  HUB LONG(10)
    Message HUB String(20) = "Hello There."
    watch temp
    watch Hub1
    watch Hub2
    watch Message
    Start:
      WRLONG Hub1, 0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9
      WRLONG Hub2, 0,1,2,3,4,5,6,7,8,9
      DO
        FOR temp = 1 to 10
          pause 5
        NEXT
      LOOP
    END
    ''  *** COMPILED WITH PropBasic VERSION 00.01.17  Sept 27, 2011 ***
    CON                                                          'DEVICE P8X32A, XTAL1, PLL16X
      _ClkMode = XTAL1 + PLL16X
      _XInFreq =   5000000                                       'FREQ 80_000_000
    OBJ vp: "Conduit"                                            'PROGRAM Start
    PUB __Program
      vp_config
      CogInit(0, @__Init, @__DATASTART)
    DAT
                      org           0
    __Init
    __RAM
                      mov           dira,__InitDirA
                      mov           outa,__InitOutA
                      jmp           #Start
    ' temp  VAR LONG                                             'temp  VAR LONG
    ' HUB LONG Hub1(20)                                          'Hub1  HUB LONG(20)
    ' HUB LONG Hub2(10)                                          'Hub2  HUB LONG(10)
    ' HUB STRING Message(20) = "Hello There.",0[9]               'Message HUB String(20) = "Hello There."
    ' watch temp                                                 'watch temp
    Start                                                        'Start:
                      mov           __temp1,__Hub1_adr           '  WRLONG Hub1, 0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9
                      mov           __temp2,#0
                      wrlong        __temp2,__temp1
                      add           __temp1,#4
                      mov           __temp2,#1
                      add           __temp1,#4
                      mov           __temp2,#2
                      add           __temp1,#4
                      mov           __temp2,#3
                      add           __temp1,#4
                      mov           __temp2,#4
                      add           __temp1,#4
                      mov           __temp2,#5
                      add           __temp1,#4
                      mov           __temp2,#6
                      add           __temp1,#4
                      mov           __temp2,#7
                      add           __temp1,#4
                      mov           __temp2,#8
                      add           __temp1,#4
                      mov           __temp2,#9
                      add           __temp1,#4
                      mov           __temp2,#0
                      add           __temp1,#4
                      mov           __temp2,#1
                      add           __temp1,#4
                      mov           __temp2,#2
                      add           __temp1,#4
                      mov           __temp2,#3
                      add           __temp1,#4
                      mov           __temp2,#4
                      add           __temp1,#4
                      mov           __temp2,#5
                      add           __temp1,#4
                      mov           __temp2,#6
                      add           __temp1,#4
                      mov           __temp2,#7
                      add           __temp1,#4
                      mov           __temp2,#8
                      add           __temp1,#4
                      mov           __temp2,#9
                      mov           __temp1,__Hub2_adr           '  WRLONG Hub2, 0,1,2,3,4,5,6,7,8,9
                      mov           __temp2,#0
                      add           __temp1,#4
                      mov           __temp2,#1
                      add           __temp1,#4
                      mov           __temp2,#2
                      add           __temp1,#4
                      mov           __temp2,#3
                      add           __temp1,#4
                      mov           __temp2,#4
                      add           __temp1,#4
                      mov           __temp2,#5
                      add           __temp1,#4
                      mov           __temp2,#6
                      add           __temp1,#4
                      mov           __temp2,#7
                      add           __temp1,#4
                      mov           __temp2,#8
                      add           __temp1,#4
                      mov           __temp2,#9
    __DO_1                                                       '  DO
                      mov           temp,#1                      '    FOR temp = 1 to 10
    __FOR_temp_1
                      wrlong        temp,__temp_adr
                      mov           __temp2,#5                   '      pause 5
                      mov           __temp1,_1mSec
                      add           __temp1,cnt
    __L0001
                      waitcnt       __temp1,_1mSec
                      djnz          __temp2,#__L0001
                      adds          temp,#1                      '    NEXT
                      cmps          temp,#10 WZ, WC
        IF_BE         jmp           #__FOR_temp_1
    __NEXT_temp_1
                      jmp           #__DO_1                      '  LOOP
    __LOOP_1
                      mov           __temp1,#0                   'END
                      waitpne       __temp1,__temp1
    __InitDirA       LONG %00000000_00000000_00000000_00000000
    __InitOutA       LONG %00000000_00000000_00000000_00000000
    _1mSec           LONG 80000
    _FREQ            LONG 80000000
    ____STRING_adr   LONG 0
    __clkfreq_adr    LONG 0
    __Hub1_adr       LONG @@@Hub1
    __Hub2_adr       LONG @@@Hub2
    __Message_adr    LONG @@@Message
    __temp_adr       LONG @@@VP_Watch+0
    __remainder
    __temp1          RES 1
    __temp2          RES 1
    __temp3          RES 1
    __temp4          RES 1
    __temp5          RES 1
    __param1         RES 1
    __param2         RES 1
    __param3         RES 1
    __param4         RES 1
    __paramcnt       RES 1
    temp             RES 1
    FIT 492
    CON
      LSBFIRST                         = 0
      MSBFIRST                         = 1
      MSBPRE                           = 0
      LSBPRE                           = 1
      MSBPOST                          = 2
      LSBPOST                          = 3
    DAT
    __DATASTART
    Hub1             LONG 0[20]
    Hub2             LONG 0[10]
    Message          BYTE "Hello There.",0[9]
    VP_Watch         LONG 0[1]
    PUB vp_config
      vp.config(STRING("var:Message(base=-1),Hub2,Hub1,temp,"))
      vp.array(@Message,21,7)
      vp.array(@Hub2,10,6)
      vp.array(@Hub1,20,5)
      vp.share(@VP_Watch,@VP_Watch+0)
    Bean
    edited 2011-09-27 23:31
    Hi Bean,
    Sharing strings works well- try this out:
    CON
        _clkmode = xtal1 + pll16x
        _clkfreq = 80_000_000
    OBJ                                  'include 2 ViewPort objects:
     vp    : "Conduit"                   'transfers data to/from PC
    VAR
      long a,s[5],b                        'vars shared with ViewPort
    PUB main
      vp.config(string("var:a,s(string=20),b"))
       'channel "s" is a string length 20 bytes
      vp.share(@a,@b)          'share from a..b
      b:=10
      repeat
        repeat a from 0 to b
          case a // 3
            0:bytemove(@s,@one,7)
            1:bytemove(@s,@two,10)
            2:bytemove(@s,@three,10)
          waitcnt(cnt+clkfreq/2)
    dat
    one byte "hi one",0
    two byte "hello two",0
    three byte "bye three",0
    You do need to allocate the same number of bytes to the string as you configure with the "vp.config" line. In my case I allocated 5 longs=20 bytes. You also need to copy null terminated strings into the string buffer you're sharing with VP- in my case I use "bytemove"...
    Hanno
    edited 2011-09-28 00:39
    Hi,
    ViewPort v4.64 is here:
    http://hannoware.com/viewport/viewport464.exe
    +when compiling .pbas files, working directory is set to directory of source pbas file
    +load button on "code" view loads spin code without connecting; compiles pbas code without "/vp" option and doesn't connect
    +run menu has new entries to load to ram/eeprom with viewport support and connect
    +channel editor does better job of configuring strings
    Enjoy!
    Hanno
    edited 2011-09-28 03:29
    Hanno,
    Ok, I get it. The strings MUST be within the vp.share() range and CANNOT be used as a vp.array().
    I'll work on this and post something later today.
    Thanks for all your work on supporting PropBasic.
    Bean
    edited 2011-09-28 06:12
    Okay, I think I have it now....
    Here is the compiler, and a demo program.
    FREQ 80_000_000
    PROGRAM Start
    temp  VAR LONG
    temp2 VAR LONG
    Hub1  HUB LONG(100)
    Hub2  HUB LONG(100)
    Mess HUB String(20)
    watch temp
    watch Hub1
    watch Hub2
    watch Mess
    Start:
      DO
        Mess = "Forward"
        FOR temp = 0 to 99
          WRLONG Hub1(temp), temp
          temp2 = temp & 15
          WRLONG Hub2(temp), temp2
          PAUSE 10
        NEXT
        Mess = "Backward"
        FOR temp = 99 TO 0 STEP -1
          temp2 = temp & 15
          WRLONG Hub1(temp), temp2
          PAUSE 10
        NEXT
      LOOP
    END
    Still todo:
    Only LET and FOR...NEXT update watch values (need to modify all other commands that update variables)
    Allow to watch IO pins (at least with MonitorINA)
    Bean
  • 4x5n4x5n Posts: 747
    edited 2011-09-28 15:34
    I'd like to take a moment to say how impressed I am at how close and quickly Bean and Hanno are working to extend the functionality of propbasic and viewport so that the two will work together! This type of cooperation is rare and refreshing to see.
    While I have to admit to not currently using either propbasic or viewport currently. They're both on my list of things to get and learn how to use over the next month or so though. A big part of why I'm interested in both is the level of cooperation between Bean and Hanno!
    edited 2011-09-28 15:56
    Thanks for the kind words 4x5n. It's really fun working with Hanno.
    This version implements IO watching.
    By default a variable "IO" shows all the pin states.
    If you WATCH a pin variable as in:
    LEDs PIN 16..23 HIGH
    WATCH LEDs
    Then IO will show the pin variable states. You may watch more than on PIN variable also.
    Typically you will use the "lsa" to view the IO pin states.
    This uses the rather slow "MonitorINA" method that does not require an additional cog. I'll try to work in the fast IO logger later.
    P.S. I also fixed all commands the modify variables to update the WATCH values.
    Bean
  • HShankoHShanko Posts: 402
    edited 2011-09-28 16:33
    @ 4x5n.
    As one of the ViewPort LAS beta testers, your comments are right on. Hanno is one of 'our' good guys to work with. And there are many others, as you will discover. The Propeller has attracted a large number of co-operative fellows, and gals, who work together quite well. That makes this one great forum.
    edited 2011-09-28 17:19
    Oops, found a minor bug. The IO view shows 1 extra bit for a PIN variable.
    If you define "LEDs PIN 16..23" then "WATCH LEDs" the lsa view will show pins 16 through 24 (should be 23).
    I have fixed it already, but I'll wait to post a new version to see if there are any other fixes needed.
    Bean
    edited 2011-09-28 17:52
    HShanko wrote: »
    @ 4x5n.
    I have noticed that this forum is full of very helpful people! I only got the prop education kit to learn about what the propeller can and can't do as well as learn how to work with it. While it's taking some time to get used to and at times I struggle with the different paradigm of use then the microcontrollers (68hc11, 68hc12 and 68hc16) that I've used in the past. The people on the forum have been very patient with my struggles. So far I really like the propeller and can see using it for various projects for years to come.
    edited 2011-09-28 20:18
    Wow Bean- this is looking great!
    I love how this is coming along. All the speed of PropBasic, simple BASIC syntax, and no complex configuration strings- it just works!
    Great job demoing how to share strings, arrays, IO state, and variables.
    I really like how you supported the individual bits for IO monitoring.
    What determines the order of the watched items? I was surprised that hub2 showed up before hub1 in the spin code.
    I like how easy it is to watch the arrays plotted in real time. I still need to work on plotting the contents of the array across the graph's width.
    Now that pbasic variable values are in ViewPort you can access them easily from other applications (labview, .net, python,...) using DDE. For example, type one of these into an Open Office Calc cell:
    =DDE("vp";"get";"Hub2")
    =DDE("vp";"get";"Hub2(2)")
    =DDE("vp";"get";"temp")
    =DDE("vp";"list";"list")
    Have you seen Tubular's use of ViewPort streaming color video?
    See here:
    http://forums.parallax.com/showthread.php?134793-Browser-s-Math-Puzzle/page2
    Thanks Harley and 4x5n for your support- I'm having a blast!
    Hanno
    edited 2011-09-29 04:17
    Hanno wrote: »
    I'll have to fix that. I had everything in one string, and arrays HAD to come first. So I added them to the beginning of the string (putting them in reverse order). But now arrays are in a seperate string, so I should be able to make the order correct.
    Hanno wrote: »
    Hanno
    Yeah, that looks really good. I want to support video so I guess that is the recommended driver ?
    Sometime in the future I'd like to change PropBasic so that it doesn't use arrays in COG ram (they require self-modifying code). And support arrays in HUB ram. Right now arrays in HUB ram can only be accessed using RDxxxx and WRxxxx.
    Bean
    edited 2011-09-29 06:21
    This version fixes the order of arrays.
    Enhanced WATCH and UNWATCH:
    - Can specify multiple names (seperated by a comma)
    - Can specify NO parameters meaning ALL variables
    - Can specify a viewport modifier with WATCH (see example)
    ' Program to show speed difference when a variable is WATCHed (450 mSec) and UNWATCHed (150 mSec)
    ' Also shows WATCH modifiers
    FREQ 80_000_000
    PROGRAM Start
    temp  VAR LONG
    time1 VAR LONG
    time2 VAR LONG
    watch temp "base=16",time1 "unit= mSec",time2 "unit= mSec"
    Start:
      time1=cnt
      FOR temp=1 to 1_000_000
      NEXT
      time1=cnt - time1
      time1 = time1 / 80_000 ' Convert to milliSeconds
      unwatch temp
      time2=cnt
      NEXT
      time2=cnt - time2
      time2 = time2 / 80_000 ' Convert to milliseconds
    END
    Bean
    edited 2011-09-29 11:26
    OOPS !!! Found a major bug in the multiply routine. I think I have it fixed now...
    If you have a previous version...Please update to this version.
    Also implemented Viewport Video support. :)
    FREQ 80_000_000
    vidBuffer HUB BYTE(19200)
    PROGRAM Start
    Plot SUB 3 ' X, Y, Color(0-63)
    x      VAR LONG
    y      VAR LONG
    temp   VAR LONG
    color  VAR LONG
    WATCH temp,y,x
    Start:
      VPVideo vidBuffer
      DO
        FOR temp=0 to 255
          FOR y=0 to 119
            FOR x=0 to 159
              color = x ^ y ' Make a pretty pattern
              color = color ^ temp ' Make a pretty pattern
              Plot x, y, color
            NEXT
          NEXT
          PAUSE 500
        NEXT
      LOOP
    END
    SUB Plot ' X, Y, Color
      __param2 = __param2 * 160
      __param1 = __param1 + __param2
      WRBYTE vidBuffer(__param1), __param3
    ENDSUB
    Bean
    edited 2011-09-29 18:21
    Okay, another update. I added the VPWait that waits for Viewport to update. You can also give an optional value that will add a delay before the next update (to give your program time to update).
    FREQ 80_000_000
    PROGRAM Start
    x      VAR LONG
    y      VAR LONG
    color  VAR LONG
    temp   VAR LONG
    WATCH temp
    Start:
      VPVideo vidBuffer
      DO
        FOR temp=0 to 255
          FOR y=0 to 119
            FOR x=0 to 159
              color = x ^ y
              color = color + temp
              Plot x, y, color
            NEXT
          NEXT
          VPWait
        NEXT
      LOOP
    END
      __param3 = __param3 shl 2
    ENDSUB
    edited 2011-09-29 18:38
    Bean,
    It's hard to keep up with you! Awesome job getting video to work- I love how simple your graphics program is. Very easy to understand.
    ViewPort has a slew of interesting features that could one day make it to PropBasic: fuzzy logic, terminal IO, up/downloading of large files, etc. However, I think changing variables from VP should be next. It's very useful when you're tweaking programs, calibrating sensors/actuators, using the Prop as a device with a VP GUI front end, etc...
    Your generated code should "rdlong" from a pointer into hub before "editable" variables are used. Spin variables can be monitored and changed just by "vp.share"ing them. For PropBasic it may make sense to use ViewPort's "control channel"- so that "editable" variables can only be edited- not watched. They just need to be allocated right after the last "watched" variable- and named in the "var" config string.
    Hanno
    edited 2011-09-29 18:43
    Hanno,
    Yes, Editable variables will be really useful (like Thomas the tank engine).
    I'll explore that next.
    Bean
    edited 2011-09-30 06:08
    Okay, I have implemented edit-able variable. But I had to "cheat". Variables are read at way too many places in the compiler to change the code without ALOT of work.
    So I made a command "UPDATE varname" that will read a variable value from viewport. One good thing is that a variable's value can only change at one point, instead of anywhere (which might cause problems).
    ' For PropBasice 1.22 in Viewport
    FREQ 80_000_000
    PROGRAM Start
    temp   VAR LONG
    limit  VAR LONG
    WATCH temp,limit "min=50,max=500"
    Start:
      limit = 100
      VPConfig "dso:view=temp,timescale=10ms,trigger=temp>25"
      VPConfig "edit:limit(mode=dial,default=100)"
      DO
        UPDATE limit
        FOR temp=0 TO limit
          VPWait
        NEXT
      LOOP
    END
    Bean
  • Kevin L.Kevin L. Posts: 10
    edited 2011-10-01 12:45
    Hi Bean,
    I think I found a bug in your compiler (V1.22)
    When I try to add a Task to your example above, it gave me a "Wrong number of arguments (1 instead of 2)" error.
    the code generated for the task is...
    PUB Init(pv_VP_Watch)
      _Fixup(pv_VP_Watch)
      Return (@__INIT >> 2) << 4
    PUB _Fixup(pv_DataStart, pv_VP_Watch)
      __InLineStr1_adr += pv_DataStart
      __InLineStr2_adr += pv_DataStart
    edited 2011-10-01 14:11
    Kevin,
    Oops sorry about that.
    See if this fixes it.
    Bean
    edited 2011-10-01 14:18
    Bean,
    Thanks, that works now.
    How about LMM /w Viewport, is that supported yet?
    It seem to partially work for me (the code seem to run but the watch does not work)
    Kevin
    edited 2011-10-01 14:45
    Kevin,
    I just tried it and I forgot to make VPWait compatible with LMM. So I fixed that.
    WATCH seems to work fine now with LMM both in the main code and in the TASK.
    Bean
    edited 2011-10-01 16:44
    Bean,
    Awesome getting "editable" variables to work. I'm fine with your "update" command- may make it less confusing for novice programmers. I didn't even know you had a LMM version/option- how does that work? I now have ViewPort running on OSX and Linux- how does PropBasic fit there? What language is PropBasic written in?
    Hanno
    edited 2011-10-01 17:20
    Hanno,
    To make program LMM simply add "LMM" to the PROGRAM command.
    PROGRAM Start LMM
    Each TASK (tasks run in other cogs) can be either native (default) or LMM by adding LMM to the "TASK taskname" line (not the "taskname TASK" that is declared at the top of the program).
    PropBasic is written in Delphi 7. Can also be compiled with Lazarus (I think that is what BradC used for BST). I can provide you with the source if you need/want it to integrate PropBasic with Viewport.
    Bean
  • FriedVFriedV Posts: 77
    edited 2011-10-02 02:05
    @Bean
    I think there is a bug in the newer version of PropBasic concerning strings:
    The following code used to work fine (I don't remember what the PropBasic version was):
    ' File......  FloatTest.pbas
    ' Author....  fgvissel  02.10.2011
    ' ----- Device Settings ------------------------------------------------
      XIN 6_250_000
    ' ----- Conditional Compilation Symbols --------------------------------
    ' ----- Constants ------------------------------------------------------
      LCD_baud            CON "T115200"
    ' ----- IO Pins --------------------------------------------------------
      LCD_tx    Pin 1    High                    'idle State High
        LCD_rx    Pin 2    Input
    ' ----- Shared (HUB) Variables (Byte, Word, Long) ----------------------
    ' ----- User Data (DATA, WDATA, LDATA, FILE) ---------------------------
    ' ----- TASK Definitions -----------------------------------------------
    ' ----- Local Variables (LONG only) ------------------------------------
    ' ----- SUB and FUNC Definitions ---------------------------------------
      LCD_Print SUB 1
      sout  SUB 1
    PROGRAM Start
    Start:
    ' setup code
    Main:
    LCD_Print "AAAAA"
    do      'FOREVER
      loop
    END
    ' ----- SUB and FUNC Code ----------------------------------------------
    SUB LCD_Print
        LCD_DC1        CON $11
        LCD_ACK        CON $06
        LCD_i                VAR LONG
        LCD_bcc            VAR LONG
        LCD_length    VAR LONG
        LCD_char        VAR LONG
        LCD_stradr    VAR LONG
        LCD_result    VAR LONG
        sout LCD_DC1
        LCD_bcc = LCD_DC1
        LCD_length = LEN __STRING(__param1)
        sout LCD_length
        LCD_bcc = LCD_bcc + LCD_length
        LCD_length = LCD_length - 1
        for LCD_i = 0 to LCD_length
            LCD_stradr = __param1 + LCD_i
            RDBYTE LCD_stradr, LCD_char
            sout LCD_char
            LCD_bcc = LCD_bcc + LCD_char
            next
        sout LCD_bcc
        serin LCD_rx,LCD_Baud, LCD_result
        ENDSUB
    SUB sout
        serout LCD_tx, LCD_Baud, __param1
    ENDSUB
    ' ----- TASK Code ------------------------------------------------------
    but now the output is $11,$02,$F5,$FC,$04.
    I think the string pointer must be wrong, because the protokoll frame is allright.
    Cheers, Fried
    edited 2011-10-02 05:10
    Fried,
    You can't use __param1 inside the loop.
    As soon as you call "sout" the variable __param1 get set to the parameter of the "sout" subroutine.
    Bean
    edited 2011-10-02 07:31
    Ooops,
    sorry about that, Fried
    edited 2011-10-02 08:19
    What I do for subroutines that call other subroutines is to use the high __paramx variables.
    Something like:
    SUB LCD_Print
        LCD_DC1        CON $11
        LCD_ACK        CON $06
        LCD_i                VAR LONG
        LCD_bcc            VAR LONG
        LCD_length    VAR LONG
        LCD_char        VAR LONG
        LCD_stradr    VAR LONG
        LCD_result    VAR LONG
       __param2 = __param1 ' Save __param1
        sout LCD_DC1
        LCD_bcc = LCD_DC1
        LCD_length = LEN __STRING(__param2) ' NOTE __param2
        sout LCD_length
            LCD_stradr = __param2 + LCD_i ' NOTE __param2
            sout LCD_char
            next
        sout LCD_bcc
        ENDSUB
    Bean
    edited 2011-10-02 10:45
    Thanks Bean, good idea!
    Another point I have with strings:
    "AB" is a string and will be compiled as such (inline string). But "A" compiles as a single character.
    So in a SUB len __string(__param1) will of course not work.
    Perhaps "A" should be compiled as $41,$00 (string) and 'A' as $41 ?
    Another point on my personal wishlist for PropBasic would be a CASE statement like in spin or C.
    BRANCH and On .. GOTO are not quite the same.
    Fried
