jitter on RC timing
I finally got around to using the counters on the prop to try measure RC timing with the intent of using it to measure resistence, etc. While it worked better then I honestly expected I did notice a bit of "jitter" on the readings. I have to admit to using a solderless breadboard which I'm sure accounts for a little of it.
My question is how do people deal with the jitter of even the 2-4 counts on the lsd that I'm seeing. Are you averaging, etc? My intent is to use a pot and a stepper motor for position control and am concerned about the problems it may cause. Of course the probability is that it's small enough not to matter but still!!! :nerd:
I noticed similar on a project a while back, and have been trying to keep up on the conversations, but I haven't had time to go back and experiment.
I did some more testing and when I soldered the components together to remove variations in conductance in the connections and increased the length of the charge pulse the jitter at the higher resistance levels was down to +/-1 least significant digit. After scaling the result the amount of jitter isn't a concern.
