Eye-Fi Wireless SD card: Propeller Hackable? — Parallax Forums
edited 2011-09-28 10:25 in Propeller 1
http://www.eye.fi/how-it-works/basics
Propeller Hackable? I could think of some pretty cool uses for Wifi connectivity via existing SD.
OBC
    edited 2011-09-27 11:40
    Jeff,
    I ran across the documentation for my Eye-Fi card last night and started thinking along similar lines. Mine might be a (significantly) older version, I don't remember having the USB/SD adapter they show. I'll need to dig around for it and see.
    Certainly could do some data logging to a PC. I'm not sure if it can talk from the PC back to the Eye-Fi except maybe for file deletion.
    If I can find all the parts to mine, I'll be happy to send them down to Orrville for a loan. You will probably get around to hacking with it MUCH sooner (and more capably) than I will!!
    edited 2011-09-27 12:10
    I have one .. I doubt it can do more then Photos as the firmware is really locked up .
    BUT a SDIO WiFI form amazon may work as it is just a SDIO device not a SD storage card that can leak data to a WiFi chip .
    edited 2011-09-27 18:30
    Nifty concept but looks like it only sends files one way. Be nice if it cold be hacked though. A 4G card and wifi.
    edited 2011-09-27 19:32
    I am playing with some of these 4G X2 and 8G Pro cards at present. I have Data Loggers that could benefit from having a transparent interface directly to the files on the card. I have already tricked the software into sending some files other than photos or videos but I will probably chase the Eye-Fi guys to see if there is a firmware update allowing access to any file. I will post as soon as I make some progress.
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2011-09-27 19:56
    Peter,
    I asked the guys at Eye-fi that very question a few years ago when there product first entered the market. They had no interest at the time. I hope it is a different story now.
    edited 2011-09-27 20:26
    The advantage of the Eye-Fi card is that it is a normal SD memory card and the WiFi is transparent to the target. So we're not trying to use the card for a general-purpose WiFi connection as there are much better ways of doing that plus it would load up the Prop's resources. However it's a great way to retrofit SD card products to make them accessible over WiFi (assuming we can).
    Thanks for the links though.
    Peter I was wondering on the load for the prop . If it was me at parallax I would be useng one of those SDIO chips to make my WiFI adapter work and selll a WIFI spinnnernet .
    have its on board Prop handle the heavy lifting ..
    now its just a SD slot some GPIOs and a most of al software .
    I recon that if a old Win CE device can boot that card then I am shure iur prop can ..
    peter
